bamk2f6tornado Bronze Donating Members 777 Member For: 11y 2m 14d Gender: Male Location: Rockhampton Qld Posted 29/03/16 05:40 AM Share Posted 29/03/16 05:40 AM *beep* f*cked Haha Link to comment Share on other sites More sharing options...
boost69 Donating Members 737 Member For: 19y 8m 29d Posted 29/03/16 09:20 PM Author Share Posted 29/03/16 09:20 PM Guys, I know there's a schematic diagram under the lid, but I haven't seen a relay for blower fan, I do see Fan 1 and Fan 2 which I assume are for the thermo fans... Link to comment Share on other sites More sharing options...
FORCEDG6E Member 145 Member For: 13y 6m 19d Gender: Male Location: adelaide Posted 30/03/16 10:49 AM Share Posted 30/03/16 10:49 AM it will most probably be the blower fan itself. very common on fgs have changed heaps of them. check you have voltage to the fan plug when fan switched on Link to comment Share on other sites More sharing options...
FORCEDG6E Member 145 Member For: 13y 6m 19d Gender: Male Location: adelaide Posted 30/03/16 10:50 AM Share Posted 30/03/16 10:50 AM give it a thump and see it it comes to life Link to comment Share on other sites More sharing options...
boost69 Donating Members 737 Member For: 19y 8m 29d Posted 31/03/16 09:18 PM Author Share Posted 31/03/16 09:18 PM FORCEDG6E, it didn't even need a thump...I just gave it a tap and on it went...thanks buddy...your advice was spot on... I had mentioned the intermittent problem with the blower fan to Ford service when I took the car in just before my MyFord extended warranty expired, and as per usual they did nothing about it... You guys reckon I should get in touch with them and see if I can get the blower fan replaced under warranty?...Or am I most likely wasting my time... Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 2m 23d Gender: Male Location: Probably above atmospheric pressure Posted 01/04/16 05:36 AM Share Posted 01/04/16 05:36 AM Just drive on rough roads so it never seizes again. Link to comment Share on other sites More sharing options...
boost69 Donating Members 737 Member For: 19y 8m 29d Posted 03/04/16 10:13 PM Author Share Posted 03/04/16 10:13 PM Lol...shouldn't be a problem on Sydney roads... 1 Link to comment Share on other sites More sharing options...
boost69 Donating Members 737 Member For: 19y 8m 29d Posted 09/05/16 01:41 AM Author Share Posted 09/05/16 01:41 AM Guys, I finally got around to pulling out the blower fan, and the connector had fused onto the blower fan socket...it was all black etc... I had mentioned the intermittent air con problem to Ford back in November, but as usual they didn't do anything about it. I just rung them now, and even though they had a record of me complaining about the blower fan not working intermittently, they pretty much said there's not much they could do... My extended warranty finished in January, and I had complained about the air con in November...(while the car was still under extended warranty), but they obviously didn't look at the problem, otherwise they would've seen the fused connected to the blower fan. Has anyone else had a similar problem with the FG?...is it the actual motor that is shorting? Or is it a problem with the connector? Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 4m 25d Gender: Male Location: Perth Posted 09/05/16 01:45 AM Share Posted 09/05/16 01:45 AM Who provided the extended warranty? Link to comment Share on other sites More sharing options...
boost69 Donating Members 737 Member For: 19y 8m 29d Posted 09/05/16 02:45 AM Author Share Posted 09/05/16 02:45 AM It was the genuine Myford extended warranty. The one that apparently is a continuation of the normal factory warranty. Link to comment Share on other sites More sharing options...
