Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 11y 6m 6d Gender: Male Location: Adelaide Posted 29/05/16 10:34 PM Author Share Posted 29/05/16 10:34 PM Im at work until 4ish mate so im going to have a look at it again tonight. Ill remove the sus bolt and double check tonight. If I have f*cked it the car will see fire. Shouldn't have cross threaded. Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 8m 12d Gender: Male Location: Adelaide Posted 29/05/16 10:58 PM Share Posted 29/05/16 10:58 PM If you need a hand you have my number 1 Link to comment Share on other sites More sharing options...
Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 11y 6m 6d Gender: Male Location: Adelaide Posted 06/06/16 03:15 AM Author Share Posted 06/06/16 03:15 AM So the turbo is back on. Did stand the turbo up right 100% with custom work on the gt bracket. Only issue is now the plumback hose is really thick and can not connect to the turbo side because it squeezes between the turbo outlet and coolant bottle to tight. So running a atmo bov but I think its leaking because it doesn't seem to have the same power as it did before. Actuator has half load preload.I have run the oil line like this as it was the best I could get it. Ill get some new squirters and fuel reg and see how much coin the tax man gives me back. Time for a retune. The tune is sh*t. Also tested the oil in and out and they are both flowing perfectly. Fingers crossed this one holds up as it will just be the weekend car. Lanos Monday to Friday. 400kms for $30 can go wrong. Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 6m 22d Posted 06/06/16 06:44 AM Share Posted 06/06/16 06:44 AM Can you take a photo front on. Doesn't look like your chra is in the correct orientation. The oil feed should be perpendicular to the ground, plus or minus 15 degrees. Looks to far around. Just an FYI on how I run my feed and orientation. Link to comment Share on other sites More sharing options...
barnz Member 3,047 Member For: 11y 2m 23d Gender: Male Location: Brisbane Posted 06/06/16 08:20 AM Share Posted 06/06/16 08:20 AM ^^this, dont kille another biz Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 8m 12d Gender: Male Location: Adelaide Posted 06/06/16 08:38 AM Share Posted 06/06/16 08:38 AM B series is different to FG the rotation is governed by the water feed hard line so Brad has it correct rotation wise here is a pik of a stock lined FG The aftermarket oil feed line could be 10 meters long and do "loop da loops" and it's not an issue as long as it's receiving oil and draining oil it's fine for use Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 6m 22d Posted 06/06/16 09:07 AM Share Posted 06/06/16 09:07 AM Yeah I had a look through some photos you posted earlier and seen that it's rotated quite far around and can't do much with it with the stock water lines. . Really goes against what Garret recommend. But as long as it drains I guess it's OK. Link to comment Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 12y 9m 8d Gender: Male Location: Central Coast Posted 06/06/16 09:14 AM Share Posted 06/06/16 09:14 AM Block da bov for dat dose Link to comment Share on other sites More sharing options...
Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 11y 6m 6d Gender: Male Location: Adelaide Posted 06/06/16 09:46 AM Author Share Posted 06/06/16 09:46 AM Its at its max movement for the coolant line. If it had more in it I would. I would block the bov matty but if I was going to do that I would want it tuned to no bov. Dont want to spike and pop a rod. Link to comment Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 12y 9m 8d Gender: Male Location: Central Coast Posted 06/06/16 12:53 PM Share Posted 06/06/16 12:53 PM that's not how blocking the bov works Link to comment Share on other sites More sharing options...
