JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 10m 22d Gender: Male Location: Adelaide Posted 10/03/16 09:13 AM Share Posted 10/03/16 09:13 AM FiftyOne you come up with dome rando sh*t on here 3 Link to comment https://www.fordxr6turbo.com/forum/topic/91782-f6-ignition-timing-fg-vs-bf/page/2/#findComment-1581994 Share on other sites More sharing options...
Lennox Member 2,586 Member For: 12y 1m 26d Gender: Male Location: Perth Posted 10/03/16 11:10 PM Share Posted 10/03/16 11:10 PM ^^ doesn't know the answer, defaults to a recommendation of 1000cc kpm injectors 3 Link to comment https://www.fordxr6turbo.com/forum/topic/91782-f6-ignition-timing-fg-vs-bf/page/2/#findComment-1582033 Share on other sites More sharing options...
Benny-4000 Member 31 Member For: 17y 2m 6d Posted 11/03/16 09:40 AM Author Share Posted 11/03/16 09:40 AM On 10/03/2016 at 7:11 AM, Ralph Wiggum said: No worries, good to see someone reading the tables well enough to notice something like that. Are you on the HPT forum? Expand Yes, I am on the HPT forum and I am so happy that I can now tune the ZF which I am now getting the hang of. Link to comment https://www.fordxr6turbo.com/forum/topic/91782-f6-ignition-timing-fg-vs-bf/page/2/#findComment-1582078 Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 9m 14d Gender: Male Location: OZ Posted 15/03/16 11:01 PM Share Posted 15/03/16 11:01 PM You can't compare the two off paper as the airflow values are different and the resulting load figure for the equivalent boost pressure (MAP) and RPM is different. For example a MAP of 75 inHG has a load of ~2.4 on a FG F6 @ 4500rpm. The equivalent load on a BF F6 at the same MAP and RPM is ~2.6. But yeah, mechanical differences like compression ratio, manifold design, head design, camshafts have minor influences on the engines airflow etc. ECU processing capability and the guy punching buttons is likely to effect is all too. Link to comment https://www.fordxr6turbo.com/forum/topic/91782-f6-ignition-timing-fg-vs-bf/page/2/#findComment-1582447 Share on other sites More sharing options...
