cobrav8 Member 1,969 Member For: 20y 1m 24d Gender: Male Location: New Zealand Posted 01/03/16 06:44 AM Share Posted 01/03/16 06:44 AM Hi there. I have a 2005 ba xr6t and have an issue with the car heating up fast when towing up hill. The car is modified, and used to behave fine, just changed recently. I have changed the thermostat I tried turning ac on and fan to full and only the passengers side engine fan is turning on. Should the drivers side fan be turning on with the other, or is it heat related and only turn on when much hotter? Link to comment https://www.fordxr6turbo.com/forum/topic/91761-second-fan-not-activating/ Share on other sites More sharing options...
cobrav8 Member 1,969 Member For: 20y 1m 24d Gender: Male Location: New Zealand Posted 02/03/16 05:09 AM Author Share Posted 02/03/16 05:09 AM Nobody knows? Link to comment https://www.fordxr6turbo.com/forum/topic/91761-second-fan-not-activating/#findComment-1581234 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 5m 23d Gender: Male Location: Probably above atmospheric pressure Posted 02/03/16 05:39 AM Share Posted 02/03/16 05:39 AM (edited) Never noticed a single fan go, I'm pretty sure it's always both. Sounds like it anyway...maybe try grabbing a fan from a wrecker if you can't see any wiring issues. They are easy to change out, just a bit of trim needs to be removed from memory, around the bonnet latch I think. I've taken mine out and put it in a bunch of times and it's not hard if you look for the screws etc. The fan itself is held in place only by two bolts at the top, and it only slips into the lower mounts that you can't reach. Just make sure you remember to PLUG IT BACK IN hahaha. I was driving along in slow traffic and overheating one day...soon figured out why. Also I never had them engage before I had a custom tune done, which obviously lowered the minimum threshold that makes the fans come on. Edited 02/03/16 05:42 AM by -Stever- Link to comment https://www.fordxr6turbo.com/forum/topic/91761-second-fan-not-activating/#findComment-1581237 Share on other sites More sharing options...
jas98 Member 1,046 Member For: 12y 9m 25d Gender: Male Location: Maryborough Qld Posted 13/03/16 01:25 AM Share Posted 13/03/16 01:25 AM check the relays ....my passenger side only turns on when air con is on then afteer a white the other lso turns on. ones low speed fan others high speeed fan Link to comment https://www.fordxr6turbo.com/forum/topic/91761-second-fan-not-activating/#findComment-1582173 Share on other sites More sharing options...
