  • Member For: 12y 11d
  On 26/02/2016 at 11:31 AM, HI PSI said:
How did you go with the main studs? Did you get them to bottom?
Expand
I dunno if you know but you know how the windage tray is spot weld to those 2 thicker parts? Well I drilled them off and just used the thin part of the tray.. and just wound the studs up a few turns.
  • Bronze Donating Members
  • Member For: 12y 18d
Good to meet and chat with you down at MTQ yesterday Jamie
Keep us updated on progress mate and think about the intercooler
  • Member For: 18y 11m
Expand
From memory, 6 mm ball bearings are meant to be inserted....
 I called Brad (Atomic) when I installed my studs, as they wouldn't bottom. He told me that I needed to install 6 mm ball bearings into the block, so that they would. happen.  Not bottoming the studs may lead to inaccurate tensioning.
Edited by HI PSI
