Vipir Member 35 Member For: 14y 10m 7d Gender: Female Location: Newborough Posted 01/03/16 09:51 AM Author Share Posted 01/03/16 09:51 AM 46 minutes ago, Turbofix said: Again sorry if I gave wrong impression!! As xr6t is injected I felt all would recognise pouring water into carby was not possible and therefore I was not suggesting Viper should do so. Also from posts compression problem seems limited to cyl 5.. Therefore is it possible the compression problem is a valve stem guide problem as I experienced? That is what I was endeavouring to contribute. And yes I do see the funny side of you having a bit of fun with my posts 2 hours ago, Turbofix said: Sorry if I gave wrong impression. As there is no carby on Viper I was pointing to my compression problem on no. 5 being a valve stem guide problem. Therefore my post was intended as a positive contribution and I did hope it was received that way Yes, No. 5 cylinder was pulling 85psi as opposed to the other 5 cylinders doing 125psi. A coil pack was replaced, a new injector was put in and then compression tests revealed the low psi. A wet test revealed pressure increased so...rings. Of course it's rings because I wanted it to be valves. But anyhoo, there we go. A camera down the cylinder indicated no initial damage to the bore, but a more detailed inspection will now be performed and photos taken for Ford Australia to consider helping with some of the costs. When I know, y'all will know. There will either be tears or champagne... Link to comment https://www.fordxr6turbo.com/forum/topic/91726-low-compression-on-no-5-cylinder-and-rough-idle/page/6/#findComment-1581176 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 5m 8d Gender: Not Telling Posted 01/03/16 09:56 AM Share Posted 01/03/16 09:56 AM (edited) Some clarity on the water issue. It is actually a thing. When water is introduced to the intake in minimal quantities, not poured, it will soften carbon that has attached to the valves and the pistons. The said carbon will then break up and disperse through the exhaust. This is not usually an issue with efi cars as the afr is usually a lot closer to stoich more often and does not build up as much carbon as cars from the 70s and 80s. We also have much better ignition systems which burn a lot more intake charge and accumulates less carbon inside the engine. The benefits of removing carbon from the cylinder are; reducing compression in extreme cases, removing sharp outcrops of carbon that can glow and cause pre ignition or detonation, removing particles that can build up and hold the valves open and more indirectly improve fuel economy through tune related retardation. It is acceptable to spray water into your throttle body with a hair dressing atomizer. This will cause no damage. IMO this is unnecessary for our cars as the carbon build up should be minimal given normal operating conditions. I don't think this has anything to do with the problem outlined in this thread but it seemed worthwhile to mention given the last several comments. Edited 01/03/16 10:05 AM by Puffwagon Extra words, grammar and a comma. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/91726-low-compression-on-no-5-cylinder-and-rough-idle/page/6/#findComment-1581177 Share on other sites More sharing options...
Turbofix New Member 4 Member For: 9y 4m 11d Posted 01/03/16 11:22 AM Share Posted 01/03/16 11:22 AM (edited) Thanks Vipir. I really do hope it works out best possible for you. Had I taken more time reading your posts wet testing increase explains rings. Edited 01/03/16 11:27 AM by Turbofix oops Link to comment https://www.fordxr6turbo.com/forum/topic/91726-low-compression-on-no-5-cylinder-and-rough-idle/page/6/#findComment-1581195 Share on other sites More sharing options...
Vipir Member 35 Member For: 14y 10m 7d Gender: Female Location: Newborough Posted 03/03/16 03:38 AM Author Share Posted 03/03/16 03:38 AM Latest update 03/03/16 The problem started in No. 1 & 3 cylinders. Scoring is really bad. No. 5 just was the end result. The mechanic says that possibly a bad batch of fuel has caused the engine to lean out, but I must have got that bad batch in the first year because I have been having this problem since I got the car. The bitch of it is that it is a problem the mechanic could never replicate, despite my permission for him to put Vipir through his paces. Perhaps if he had been able to replicate the problem, and do so earlier in the piece, I would not have ended up causing such dreadful damage to my beloved car. Engine's going to be taken out and have to be rebuilt. I feel like my ignorance of all things mechanical is my saving grace at the moment. Perhaps if I knew just how catastrophic this is I might be howling in tears. So, I don't know if that's the end of it. We know the problem. Now it's just a matter of waiting for a quote and seeing if Ford Australia will help out in anyway. I am not sanguine. Link to comment https://www.fordxr6turbo.com/forum/topic/91726-low-compression-on-no-5-cylinder-and-rough-idle/page/6/#findComment-1581313 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,589 Member For: 17y 2m 28d Gender: Male Location: Melbourne Posted 03/03/16 03:53 AM Share Posted 03/03/16 03:53 AM If there's scoring and bore damage, buying a new short motor from Ford will be your cheapest and best option in terms of both parts expenditure and most definitely labour costs. To repair a damaged engine internally is an expensive (parts) and time consuming (read labour costs) process. Labour costs should just be remove (+$), replace ($0), refit (+$). Link to comment https://www.fordxr6turbo.com/forum/topic/91726-low-compression-on-no-5-cylinder-and-rough-idle/page/6/#findComment-1581314 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 9m 14d Gender: Male Location: Perth Posted 03/03/16 03:56 AM Share Posted 03/03/16 03:56 AM You're missing some significant steps there keify...like assembling the short motor. Link to comment https://www.fordxr6turbo.com/forum/topic/91726-low-compression-on-no-5-cylinder-and-rough-idle/page/6/#findComment-1581316 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,589 Member For: 17y 2m 28d Gender: Male Location: Melbourne Posted 03/03/16 03:58 AM Share Posted 03/03/16 03:58 AM you mean assembling the long motor (reverse of the removal of the "damaged short" motor)? the short motor comes pre-assembled from Ford, as far as I know. Link to comment https://www.fordxr6turbo.com/forum/topic/91726-low-compression-on-no-5-cylinder-and-rough-idle/page/6/#findComment-1581317 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 9m 14d Gender: Male Location: Perth Posted 03/03/16 04:00 AM Share Posted 03/03/16 04:00 AM A short motor is the block and rotating assembly. No cylinder head, No sump, No ancillaries. Essentially this- 1 Link to comment https://www.fordxr6turbo.com/forum/topic/91726-low-compression-on-no-5-cylinder-and-rough-idle/page/6/#findComment-1581318 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,589 Member For: 17y 2m 28d Gender: Male Location: Melbourne Posted 03/03/16 04:02 AM Share Posted 03/03/16 04:02 AM Yes and if it comes in that from from Ford (which I'm pretty sure it does) then you just put the head/sump on (of course I'm over-simplifying the process) and of course the ancillaries (ancillaries would be necessary to remove/refit for even a long motor remove/replace) Link to comment https://www.fordxr6turbo.com/forum/topic/91726-low-compression-on-no-5-cylinder-and-rough-idle/page/6/#findComment-1581319 Share on other sites More sharing options...
Vipir Member 35 Member For: 14y 10m 7d Gender: Female Location: Newborough Posted 03/03/16 04:25 AM Author Share Posted 03/03/16 04:25 AM I could weep right now, but I have to strap on a pair and go have my once-a-month meeting with my boss and try to succumb to tears. A librarian with a passion for hot cars and whose hot car is currently getting lemon aid. Is it a lemon? Stay tuned. Next week we'll be getting the quote and options. PS: he was very impressed, I think, with my questions, and my little bit of understanding thanks to all of your inputs. "Leaning out" was a new one which I will have to look up. Link to comment https://www.fordxr6turbo.com/forum/topic/91726-low-compression-on-no-5-cylinder-and-rough-idle/page/6/#findComment-1581320 Share on other sites More sharing options...
