  • Member For: 9y 10m 4d
Hi all I would like to ask you all if you have come across any rough idle problems in a ba Xr6 turbo I have replace plugs coils oxy sensor and I still have the problem every time I changed those parts it ran ok for about a day then it would come back I also have a bit of powers loss it doesn't seem to boost as hard as I hoped I am thinking about replacing the turbo intercooler piping but I don't know for sure there is a boost leak or an issue with the piping to begin with I would like to know if there is a way that I can test for a boost leak thanks and look forward to your response
Edited by Hotxrturbo6
https://www.fordxr6turbo.com/forum/topic/91694-boost-problem/
  • To Loud
  • Member For: 13y 4m 16d
Welcome to the forum. We hope you enjoy your time on the forum.
I think you might not get a reply any time soon, as we tend to fear those the sign up to the forum and post once.
When they get the answer that they after, they tend to run and never to be seen again.
We normally advise new member to use the search function at the top right to find the answers you want, as these sort of questions have been asked previously.
Search and yee shall find.
Hopefully someone with the know how will reply soon. This post is a bump for your thread as well. :)
  • Member For: 9y 11m 24d
Have you got a boost gauge and if so have the typical readings changed? Or if you have an obd Bluetooth adaptor and the Torque app (both are cheap if you don't) you can get boost pressure from the ECU and then let us know.
Is the car stock or if not what mods?
I'm guessing it would be hard to pressure test the intake system for leaks without some sort of special equipment. But that's getting beyond my level of expertise.
I'd check all of the clamps before doing too much though, if you haven't already.
Thanks El my mechanic has just suggested to put a boost gauge on I also have an obd wifi adapter but I use an ipad with a dash command app plus obd doctor but I still can't get it to work properly I also had the cat checked out today and it was fine the only other thing I'm gonna try now is the intercooler piping maybe injectors or fuel pump thanks again for your reply and hope to hear more advice or suggestions
  • Member For: 16y 5m 3d
Throttle positon sensor. Common issue. Causes rough idle and lack of power. Pull the throttle body off and clean it. Might help your issue if not fix it and it'll only cost a can of carby cleaner.
  • 1 month later...
