boost69 Donating Members 737 Member For: 19y 9m 1d Posted 15/03/16 11:32 PM Share Posted 15/03/16 11:32 PM Ok so it looks like they will still keep producing the stock XR6T just for the police force... Link to comment Share on other sites More sharing options...
stubbietubbie Filthy weeb Member 1,870 Member For: 12y 4d Gender: Male Posted 16/03/16 12:19 AM Share Posted 16/03/16 12:19 AM Quote Considering that its $55,990 price... Yeah, right. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,242 Member For: 16y 10m 9d Gender: Male Location: Melbourne Posted 16/03/16 12:21 AM Share Posted 16/03/16 12:21 AM ahh man... XR6 sprint FTW Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 2m 26d Gender: Male Location: Probably above atmospheric pressure Posted 20/03/16 04:36 PM Share Posted 20/03/16 04:36 PM Quote Officially, Australia’s most powerful six-cylinder engine (and the only all-Aussie production engine), delivers 325kW at 6000rpm and 576Nm at 2750rpm – conveniently 1Nm more than the XR8 and well up on the 270kW/533Nm figures of the standard XR6 Turbo it replaces, and the 310kW/565Nm outputs of the old FPV F6. But then there’s the official overboost figures claimed by Ford for the first time for its beefy Barra turbo-six, which is based on the higher-compression XR6T engine (8.7:1, rather than the F6’s 8.5:1) but adds the F6’s larger turbo, bigger 82mm injectors and 50 per cent bigger intercooler, plus a new lower airbox and Ford-first carbon-fibre air intake with 45 per cent better air flow, stiffer GT F transmission mounts, bespoke engine calibration with individual boost maps for each gear ZF auto calibration and, for the first time, launch control. Ford claims 370kW and the same 650Nm torque peak as the XR8 Sprint in 10-second transient boost mode when conditions (read: intake manifold air temperature) allow, which not only peaks above 14psi earlier and for longer than in the F6, but resets with every gear change. Given you’re unlikely to spend a lot more than 10 seconds in any given gear during enthusiastic use, and that Ford guarantees there’s never less than the nominal 325kW/576Nm outputs available, it’s a recipe for rapid, repeatable standing-start acceleration and bullocking in-gear flexibility. Do they mean 82lb? Nozzles that are 82mm wide would flow a hell of a lot of fuel hahaha. Is that the size of the FG F6 injectors? I make do with 42lb. Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 2m 26d Gender: Male Location: Probably above atmospheric pressure Posted 20/03/16 04:47 PM Share Posted 20/03/16 04:47 PM (edited) Last post not showing to edit so here Can't recall or see if I linked the article: http://www.motoring.com.au/is-fords-falcon-xr-sprint-australias-quickest-car-101758/ Edited 20/03/16 04:49 PM by -Stever- Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,242 Member For: 16y 10m 9d Gender: Male Location: Melbourne Posted 20/03/16 11:01 PM Share Posted 20/03/16 11:01 PM (edited) you posted the XR8 Sprint graph twice and didn't mention the article originally. Pretty little excel graphs... ooooooo With the 82mm, they could be talking about the length... but I doubt it. Probably do mean 82lb... The current F6 injectors are definitely NOT 82lb... if the XR6 Sprint is meant to be 82lb, it'll be the biggest stock injector by quite a long way. with regard to the car itself... ooooooooooooooohhhhhhhhhhh yeaaaaaaaaaaaaaaaaaaaaaaaahhhhhhhhhhhhhhh winning XR6T Sprint. Edited 20/03/16 11:02 PM by k31th Link to comment Share on other sites More sharing options...
.Stripes. All stock bar the k&n panel filter Silver Donating Members 8,061 Member For: 12y 11m 6d Gender: Male Location: Perth Posted 20/03/16 11:02 PM Author Share Posted 20/03/16 11:02 PM Yayyyyyy for forum upgrades now loading posts... Link to comment Share on other sites More sharing options...
.Stripes. All stock bar the k&n panel filter Silver Donating Members 8,061 Member For: 12y 11m 6d Gender: Male Location: Perth Posted 20/03/16 11:02 PM Author Share Posted 20/03/16 11:02 PM That was meant to say "not" loading posts...but given it won't even load the post I just made, I can't farken edit it... 1 Link to comment Share on other sites More sharing options...
barnz Member 3,047 Member For: 11y 2m 30d Gender: Male Location: Brisbane Posted 21/03/16 12:04 AM Share Posted 21/03/16 12:04 AM fords not being completely honest about figures imo, most suspected the 6 would be quicker but when official figures were released this theoretically shouldn't have been possible with the v8's torque curve holding 575nm flat from 2200 all the way to rev cut at like 6500. that should have nullified the 6's power under the line advantage but rumors from ford testers are the 6 just pips the 8. The only way it could really do that is if its making power differently or just more than what they have claimed. the 50kg more the 8 weights wont make that much difference I wouldnt think.. Link to comment Share on other sites More sharing options...
Krazy Kyle Get It To Wheelspin Uncontrolably Then Give It Another 5 Pounds Cruise Control 2,697 Member For: 14y 3m 29d Gender: Male Location: Work Posted 15/05/16 07:45 AM Share Posted 15/05/16 07:45 AM http://www.caradvice.com.au/440319/ford-outsells-holden-for-first-time-since-1999/?source=Facebook&utm_medium=CPC&utm_content=News&utm_campaign=FB_Competitor_MF_18-44_Resolve Link to comment Share on other sites More sharing options...
