  • Member For: 22y 7m 3d
I have installed a blow off valve with a trumpet. I can hear the air release it does not come out of the trumpet. It is only coming out of the vents on the side? I took the trumpet off and blew through it and it whistled. I ran the car without the trumpet and it makes the exact same noise with it on. What can cause the trumpet not to work? I have adjusted the tension and installed different springs with no luck. Can anybody help???? :thumbsup:
https://www.fordxr6turbo.com/forum/topic/9160-blow-off-valve-help/
  • Replies 34
  • Member For: 21y 7m 21d
watch it basher, I know one of the boys in TSV and he is ruthless and will ticket you without a glance for that. My friendly advise remove it before you cross paths.
  Basher_tsv said:
I assume you have it on the correct way around ?
I installed a GFB Stealth FX over the weekend and noted that it was to be installed opposite to how the factory Bosch bov was installed ... just a thought ?
Cheers,
B
Around the wrong way? It can only go on one way? I unpluged the old blow off valve and the pipe closest to the firewall is where I connected it and blocked the other pipe up. Is this correct? This blow off valve does not have a return pipe.
  • HEINRICH PERFORMANCE AND TUNING
  • Member For: 21y 4m 15d
you need to put it on the hose that comes off thi throttle body end and block off the air filter end
????? I installed it on the end closest to the firewall. (The shorter pipe). Not the pipe that goes under the intake. Which I thought was the return pipe. Is this the correct one?? :unsure: Maybe a pic if someone has one.
  • Member For: 21y 10m 17d
  Miyagi said:
Curious: are BOVs illegal?
Blow off valves are only illegal if they vent the boost pressure into the atmosphere. If they are plumbed back in everything is ok.
