gsd112 Donating Members 604 Member For: 14y 5m 1d Gender: Male Location: Penrith Posted 10/01/16 12:35 AM Share Posted 10/01/16 12:35 AM Hi Guys,Hopefully someone can help me?I had a coolant flush last Monday and I supplied a new coolant reservoir and cap (repco). All went well till Thursday when I got to work 50km drive it vented the whole tank on the ground. This is the first time I had run the car without the a/c on since the flush. I let it sit all day and I topped it up to half way between Min cold and Max cold marks. I drove around 25kms with a/c on and stopped and it was just below the hot max mark and stayed there. The rest of the way back to the mechanics I turned off the a/c and when I got to the mechanic it vented again. So the mechanic said it was the cap due to the radiator hose being soft and the system wasn't holding pressure.So I changed the cap with a genuine one and took it to work today and it did it again with a/c off.Any ideas what might be causing this? The temperature hasn't changed, its not going over half even if giving it a hard time. Link to comment Share on other sites More sharing options...
julesk_1972 Member 267 Member For: 12y 6m 12d Gender: Male Location: Perth Posted 10/01/16 03:28 AM Share Posted 10/01/16 03:28 AM Imho air trapped in the system, me, I fill then squeeze top hose, repeat until takes no more fluid.Or use a bleed nipple if it exists. Link to comment Share on other sites More sharing options...
barnz Member 3,047 Member For: 11y 2m 17d Gender: Male Location: Brisbane Posted 10/01/16 05:28 AM Share Posted 10/01/16 05:28 AM Shouldnt you also do it with the heater on as well? Link to comment Share on other sites More sharing options...
gsd112 Donating Members 604 Member For: 14y 5m 1d Gender: Male Location: Penrith Posted 10/01/16 05:33 AM Author Share Posted 10/01/16 05:33 AM All this has been done. I don't know where to go from here. I don't know if I should go back to the original guy and say fix it or just cut my loses and go to a forum sponsor who normally services it but I thought the local guy cant mess a coolant change up. Any idea why its only when the A/C is off? Link to comment Share on other sites More sharing options...
gsd112 Donating Members 604 Member For: 14y 5m 1d Gender: Male Location: Penrith Posted 10/01/16 06:18 AM Author Share Posted 10/01/16 06:18 AM I have no pressure in the system. I can take off my reservoir cap after a 30min drive without any issues what is going on? Link to comment Share on other sites More sharing options...
Wilko16 Donating Members 1,672 Member For: 17y 2m 16d Gender: Male Location: Melbourne Posted 10/01/16 08:34 AM Share Posted 10/01/16 08:34 AM Shouldnt you also do it with the heater on as well?Coolant is always flowing through the hearter core, the temp control knob/button just controls a little door inside the climate controlBlending hot and cold air to get the set temperature Old cars had heater taps, anything with climate control has a blending door Link to comment Share on other sites More sharing options...
Spookyluke New Member 1 Member For: 6y 5m 26d Posted 05/10/18 03:56 PM Share Posted 05/10/18 03:56 PM I have no pressure in my cooling system at normal running temperature. Once switched off it starts boiling in the top radiator hose and build’s pressure up till boiling stops but don’t lose coolant. Any one know what’s happening? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,200 Member For: 16y 9m 27d Gender: Male Location: Melbourne Posted 05/10/18 11:17 PM Share Posted 05/10/18 11:17 PM Thermosiphon, is likely what is occurring with that boiling. you'll definitely have pressure in the system at normal running of the engine, or you'd most certainly have a leak. Have you tried "gradually" loosening the radiator cap (very slowly), while it's running, to see if it has pressure? Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,099 Member For: 10y 8d Gender: Male Location: South Australia Posted 05/10/18 11:32 PM Share Posted 05/10/18 11:32 PM 14 minutes ago, k31th said: Have you tried "gradually" loosening the radiator cap (very slowly), while it's running, to see if it has pressure? Squeeze the top hose Link to comment Share on other sites More sharing options...
Ivn543 New Member 2 Member For: 4y 7m 15d Posted 02/05/22 09:28 AM Share Posted 02/05/22 09:28 AM Has anyone found a solution to this because I'm having the same issue. Link to comment Share on other sites More sharing options...
