  • Member For: 10y 10m 9d
Yeah I'm more after do it once do it right fix, there may we'll be nothing major wrong with my engine, it ran for max 10secs after light come on by the time I could pull over. I'm only chasing 600hp max ever so whatever my best option is I'll go with it. I want reliable 600hp but
Who reckons it's worth trying a new atomic pump and gears on the engine and seeing if it's all ok. Worse case scenario is I have just bought the new pump and gears for the new engine if needed???
  • Member For: 17y 7m 2d
I think it would be worth trying... Not hard to remove the big end caps and check the bearing when you remove the old pump housing and gears
If your big ends survived it will be all good
  • Bronze Donating Members
  • Member For: 12y 2m 17d
What's the difference between the ford and atomic pumps?
Is there a thread somewhere I could have a read of maybe?
  • ...JD TUNING ADELAIDE...
  • Member For: 17y 23d
Ford gear sets are ( iirc ) powdered cast and atomic are a billet, it's the violent force placed on the ford gears which make them basically disintegrate on the limiter
Yeah I understand about the gear Jet but what about the pump/plate thing it's attached too?
  • Talks Cheap, Let's Race
  • Member For: 18y 7m 8d
Atomic oil pump has been blueprinted and bypass valve has been modified
Yeah I think whilst it's off we will check bearings also. If it's stuffed it's going to cms next year sometime or sadly maybe the year after all depends on the house renovation progress.
Atomic oil pump is better in every way type it in on youtube they give you a run down
