  • MattyP
  • Cruise Control
  • Member For: 13y 2m 1d
350 on 98 is a bit of a stretch with the standard fg turbo
E85 sure no problem
  • To Loud
  • Member For: 13y 7m 5d
On 7/12/2016 at 9:19 AM, mightbuyaford said:
If the clutch is slipping put it in like 5th @ 40kmh and load it up. If it doesnt slip there your pretty safe
Well if I am travelling at 40kmh and put it in fifth, the revs sit just under 1000rpm.
I then put the foot down and the car struggles to accelerate but the clutch manages to hold on okay.
It does hold on up until boost kicks in and then the speedo literally jumps from 80/90 all the way up to 120, but the car is not going any faster.
I take it the clutch is slipping at this point, but I get no smell in the cabin.
I also check the rear view mirrors for smoke incase the tires have lit up, but not the case.
  • Member For: 11y 1m 22d
E85 sure no problem
Was starting to run out of puff after about 315 I think.
You think a 2nd hand F6 turbo will do the job on 98? or even a 2nd hand one off a BF?
Any more supporting mods you think I should go with?
It wont be getting hammered flat out so ill take the risk lol
Thanks heaps!
  • Member For: 11y 7m 15d
Its slipping, youve confirmed so dont do that any more lol. It wont always smell, smell just means you have put a sh*tload of heat into it. You will probably find the discs arent that worn, probably seriously damaged by heat though. Just not enough clamping force to stop it slipping.
  • MattyP
  • Cruise Control
Yeah it would do the job nicely
But you will loose that awesome low down punch that standard turbo gives
If.You have the time and resources mod yours into a gtx3576 that'll flow around mid 300s on 98 and keep most of the low.down response
I have heard that is the way to go, love that punch the standards ones have!
Any suppliers or company's you know that do a good job modding them?
Nick
  • MattyP
  • Cruise Control
Only in Sydney mate unfortunately
You're exhaust and fuel pump maybe limiting your power though
its not completely fubar then but def time for replacing. The aggressive on ramp of boost is breaking the clamp pressure. Will be fine to cruise on until you can replace but dont go smashing it and kicking it etc etc
replace as soon as you can
