My Bf Xr6 Na Engine With Turbo
  • less WHY; more WOT
  • Site Developer
  • Member For: 16y 11m 26d
I'm not so confident an FG cat-back would fit... with some fiddling maybe but it'd be hassle... the part I'd be worried about is going over the rear suspension.
  • Site Developer
ah of course, I remember that thread now and he said he had no issues getting around the rear suspension and rear bar etc... good job on bringing that up... that thread also says the turbo sits further back and higher up with the FG manifold, so you'll need a customized dump or cat to fit up to the new location of the cat unless you also change to an FG exhaust manifold and the associated coolant lines etc that come with that.
  • Dropping a turd
  • Member For: 17y 5m 9d
2 hours ago, k31th said:
4 inch dump with a 5 inch cat and a 3.5 inch exhaust is plenty for big big power.
No its not.
  • Bronze Donating Members
  • Member For: 13y 8m 15d
The dump pipes are different though between ba and FG. So I would interested if the interface between catbacks is the same, at least in the xforce range.
If xforce was smart they would keep the flange mount in the same spot to allow interchangeability
  • Site Developer
1 hour ago, arronm said:
No its not.
I guess you may be thinking in different terms to me, then... big big might be around the 500rwkw mark and 3.5" will easily flow that far. 1000kW it's probably not going to be enough haha
