My Bf Xr6 Na Engine With Turbo
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 5m 27d
Why are you stuff arsing around with boost T’s and Eboost’s ? 🤔
Hook up factory boost control and tune the ECU correctly and away you go, this recipe is a proven method without negatives.
If you need help with something just ask mate as this bus should be cranking by now with everything you’ve thrown at it.
  • Member For: 9y 1m 19d
I don't have the wiring for the boost solenoid in my harness. I have considered trying to wire it in manually as my ecu has the 3 main connectors but not 100% sure if I can do that?
  • less WHY; more WOT
  • Site Developer
  • Member For: 16y 7m 17d
#justNAtoTthings
Just wire it up mate.
if you fit the Eboost2 it will do exactly the same thing as a boost T “IF” you don’t have RPM inputs which require a driver tach module
Honestly just get all the turbo stuff and make it a factory turbo vehicle and have great closed loop control
  • 4 months later...
Been a bit quiet lately, new job and waiting for Plazmaman parts to arrive. 12 weeks on order but well worth the wait!
Plenum and piping all done, looks heaps better. Also installed the Streetfighter 1000hp module. Nice and quiet now.
Will put it on the dyno once Christmas is out of the way. Done a bit of road testing and cleaned up the fueling but won't be pushing it.
20211205_105310.thumb.jpg.791de9925edac3c09bbf8498adaa98a9.jpg20211204_164752.thumb.jpg.954ef200b4eef734da9b09303a2157b5.jpg
  • Like 3
  • 10 months later...
