My Bf Xr6 Na Engine With Turbo
  • Member For: 9y 1m 23d
More parts arrived today, waiting for some stuff to come from the USA so not sure how long that will take, then can get the box built.
TCE will be making a custom torque converter to suit. Probably won't have the box ready for another 3 or 4 months depending on the transmission builder and how lazy I am getting the car modified and everything fitted.404a4774633daf39b297dad1cbcf1571.jpgca2e55f81f914708ba12c92f086f1e9c.jpg98ca2303035b20b65148a6123f692afa.jpg3f3b10e76c209747ca45d0e164bd3b9d.jpg
Yep, do it right the first time and build it stronger than required saves lots of headaches and money down the track.
All these parts are rated to 1500hp+ so shouldn't have to worry about it again
Yep done the 360 degree thrust bearing
Cars been in the shed with no engine for 2 months already and most I've done is the main bearings and electric power steering haha been too lazy and now it's getting too hot
Had a crack at fitting the shifter today, made some mounting brackets out of some 3mm thick aluminum right angle plate. Had to play around a little with the height to get the shifter to sit where I wanted it too. Came up alright I reckon.
Used the 6 speed surround and modified it to fit snug and even got the boot on it too.
4806055550fc2466cd428ba03309c8e1.jpg7e8bfc928288a1030917c0963ce65ad6.jpga896270e94410ad4f991f358312875d7.jpg5f54f60b7d55d184594dbf236a540f7a.jpg
  • Like 5
Got more parts today, nearly ready to start assembling the box. Still waiting for the bellhousing though and pump gears and billet servo should be here from the states this week hopefully.
Got a Reid roller bearing extension housing, Sonnax billet roller bearing governor support, 3 inch deep transmission pan, TCI Kevlar extra wide bands and Sonnax Extreme input shaft. b20c4230041e2828655ad38578aa4482.jpgbff0f0381bfbc7fc9e83eda7b55ca4f2.jpga6b77093c83d3ab1e9d2a3c3d506c771.jpgaae818fcd8d88e3f57daef6d38ceb2b2.jpg74e847be085428c4444f66153c4efc18.jpg
And Sonnax 10 clutch high drum
  • Like 2
  • 2 weeks later...
Pumps been modified, new turbo 400 stator tube pressed in, billet gears and PTFE bush. Parts from Summit showed up so it's ready to bolt together as soon as the bellhousing rocks up.
fd55cf4ab7e33a038169ef11c88a910d.jpg19ca5786876ff3819ce745ea98a10ddb.jpg7473a5c33f95872f1e4d25810c7211e6.jpg57f5066224180def8d78f64f72ddae36.jpg
  • Like 3
