  • Dropping a turd
  • Member For: 17y 5m 25d
  On 26/04/2018 at 11:35 PM, NA_TURBO said:
Got bored. Thought I'd upgrade the fuel system hahaf5a5d51939cb50e7e4418e11bac37ea0.jpg
Expand
Luckily these days with so many system available we dont need to have fuel in the car.
E85?  Have you looked at process west and plazmaman.
  • Member For: 9y 6m 13d
I'd love to run E85 but we don't have access to it here so it's just as much power as possible on pump 98 for now. But all pumps and lines are E85 safe just in case.
  • Dropping a turd
That's a 500+ rwkw setup.  How much power you going?
I reckon this is all you need
https://plazmaman.com/wp-content/uploads/2017/02/SURGE-TANK-XR6-7.jpg
Edited by arronm
500rwkw + in the long run. Motor is built to handle it, rear end is set up so just the gearbox is left then it will be pushed. I'm having trouble with the Walbro 460 draining the swirl pot sometimes so thought if I was build a surge tank I'll do it properly.
  • Dropping a turd
460 on 98 will go big power.  Your pot obviously hasn't been modified.
Yeah I'd say so. It won't matter soon once this tank is finished. I'm just making the fuel lines for under the car with 3/8 aluminium tubing.
