Ba Xr6 Turbo Missfiring Under Wot - With New Coils And Plugs
  • New Member
  • Member For: 10y 2d
Hi guys
Hoping someone might be able to give me an idea where to start with this...
2003 BA XR6 Turbo, 125000KM. I am the second owner since I got it at 120000KM where it was in stock standard form around 8 months ago.
A week after owning it I took it to HorsePower Factory and got a basic custom dyno tune, cold air intake, with the factory fuel injectors and valve springs left alone.
All was well for 3000KM and then the gearbox started slipping, so I had the BTR 4 speed rebuilt to OEM spec less than 2000KM ago. When I got it back the car was going great, feeling a lot of responsive and agressive.
A few weeks later, it started missing at idle so I swapped the coil packs and spark plugs for new genuine Ford ones. Since then, it idles perfectly, but I now get a loud backfire at wide open throttle when shifting into 2nd. And just now tonight I noticed it is missfiring fairly badly around 50% of the time when WOT from 80kph... sometimes its a short missfire and it clears and keeps pulling hard, othertimes its spluttering really badly so I back off the throttle. Tonight was the first time I had tried WOT from 80KPH since doing the plugs/coils a month ago.
Aside from that, it drives great as my daily driver, and sits on 110kph towing my dirtbike trailer no worries.
I have checked all the air intake hoses and everything is still in place since I did the plugs and coils. I am wondering if it is something to do with the spark plug gap? In my receipt from HPF it shows "re-gap spark plugs as required"... so perhaps these new OEM ones aren't fitting the tune? Or perhaps I have a faulty coil pack, which would be bad luck as they are brand new.
Unfortunately I threw out the old coil packs and plugs.
Is it common to modify the spark plug gap when tuning these? Should I just ask HPF to re-gap some new plugs for me?
Thanks in advance for any ideas you have, love driving this car and looking forward to sorting this out.
Cheers,
Tim
  • To Loud
  • Member For: 13y 6m 1d
Please take this with a grain of salt, I am no expert, but I think this may be the valve springs mate.
Can Luke please tune in and advise?
  • Member For: 17y 6m 11d
If your boost is higher than standard you need to gap your plugs down
.7 or .8 gap should be good
  • Moar Powar Babeh
  • Member For: 19y 8m 8d
^WHS
  • Dropping a turd
  • Member For: 17y 7m 5d
As others have said. It's more than likely plug gap. What ones did you install
  • Moar Powar Babeh
Cheers,
Tim
Yeah sounds like valve springs /end italics
Also cheers and Tim in the one post, how did we miss that?
  • To Loud
Luke, that is why I thought it was valve springs, due to that line in Italic.
It's gonna be a pain in the ass to get done, may as well upgrade a few other parts, if you got plans to upgrade and get the valve springs done to.
  • Moar Powar Babeh
OP changed plugs and Coils. Problem started. Regapping the plugs to the correct range is the place to start.
