  • Member For: 11y 11m 22d
Can someone get Luke to explain what what happened exactly?...What was the contributing factor causing failure? Does failure mean almost milkshake?
This would suck if the heat exchanger is not as good as its made out to be...
Edited by PTR_NITRO_FG
  • Moar Powar Babeh
  • Member For: 19y 7m 24d
I have a feeling your correct.
My car had an earth issue at the fusebox. Cue stray current and electrolytic corrosion. Luckily for me I always park the Typhoon and Pop the bonnet and let it run down to cool off.
I noticed the oil in the header tank and popped header tank cap and then shut it down and dropped the coolant and trans fluid. It appears I caught it while the trans was forcing oil into the cooling system and relieved the pressure in the cooling system before it had a chance to force it back the other way once there was no pressure in the cooler circuit.
I dropped the trans pan and there was a minuscule amount of coolant in the pan so I'm hoping i've dodged a refurb on the trans, if not it's an excuse to refresh it.
I'd still run the PWR now that I have found the issue that caused it to fail but I've gone to the effort (begrudgingly) to install the Air to Oil.
Stay tuned for honest feedback on trans performance with an air to oil vs the heat exchanger.
  • Like 4
  • Dropping a turd
  • Member For: 17y 6m 21d
I think both in series is the go. Just hard to put an oil to air up the front with the intercooler in the way. If its remote it needs a FAN. This is where I put my B & M oil cooler on the F6. Fan draws air. Is 32mm thick and very similar to Ralphs Derale. Pwr std coolers are only 19mm thick
Territory setup is below. I would mount all coolers in the front on an N/A
  On 09/12/2015 at 10:04 AM, Ralph Wiggum said:
But doesnt this darude kit have a fan? ^^^ Edited by PTR_NITRO_FG
  • Member For: 17y 5m 23d
I'm tuned in!
  • Member For: 17y 6m 9d
Thanks for enlightening us Ralphy, still curious why you fitted it up front as opposed to the PWR location? - just an airflow thing?
Would have saved the extra hose cost etc.
You mentioned it came with a temp switch, was this on top of the cooler price or part of the kit as it isn't mentioned in their promotional stuff, although I see they do temp switches as accessories.
  • Moar Powar Babeh
There was no room for it under the car hence the location it's in. 15850 kit includes the switch and adaptor fitting.
  • Member For: 17y 5m 26d
Do you know where the cooler failed?
I know you said you had an electrolysis problem, did it eat a hole through the core or maybe a thin weld ?
Definitely not a good thing, can cause pitting throughout the donk :-(
Awesome info , thanks for taking the time to share.
I look forward to the comparison with the PWR.
