Ba Xr6T Back Firing At 4000Rpm+
Clint0n
  • Member For: 9y 8m 12d
Full set of new plugs and coils sorted my backfire at similar rpm (missed spark allowing unburned fuel into exhaust, then kaboom). Could be other things too though.
Agree that if one coil is stuffed the others are likely similar age. If you pull everything off to change one, might as well do the lot. How many km on existing coils? If they're old and have had a good life, not really wasting money to replace whole set.
Mechanic put cheapies in mine and problems continued. Quality coils is important. I replaced myself with good stuff and problem solved.
  • less WHY; more WOT
  • Site Developer
  • Member For: 16y 8m 24d
The turbo dying will just mean you'll get a LOT of oil smoke out of the exhaust. It won't cause a backfire. A backfire could have destroyed the turbo, though (unlikely)
Tow it to a mechanic/tuner asap.
  • Member For: 11y 1m 14d
Not if it has starved keif, seals yes lots of smoke. Backfire could have been fuel, ive popped an intercooler pipe before and gone ah fark it and driven home and it smelt rich as. STFT can only go about 15% or something either way. However it should throw a code if the stft has wandered that far. May not activate the CEL though
Edited by barnz
  • Moar Powar Babeh
  • Member For: 19y 3m 11d
Valve springs.
"back fire" is quite a generic term
22%
+22 is my target when I tune. I figure it's important to make sure the injectors move as much as possible so they don't get sticky?
