Exhaust Gas Temperature Probe
South man
  • Member For: 11y 1m 28d
Hey guys,
Im taking the ute in to get the temperature probe sensor welded into my dump pipe, the exhaust is already fitted to the ute and I was wondering do I need to worry about any swarf/metal filings going into the dump pipe, my way of thinking is being after the turbo I shouldn't have anything to worry about? All they need to do is drill about a 10mm hole and weld the fitting in place.
Thanks
  • Bronze Donating Members
  • Member For: 11y 10m 12d
Someone else is fitting an EGT......sweeeeeet
Now I'll have someone to compare readings with :)
Shut up Late model camira boi
Actually while I'm here, give me a ring 2torrow if ya can please jet
Completely fine, few bits of swarf will just blow into the muffler
What's the reason for the EGT probe ?
Curiosity or is it for tuning purposes ?
Just to keep an eye on things, good way to know if its running lean etc, I know that heat is the main killer of these engines. Can never be to careful!
Is your probe in the dump pipe? I know the best place for them is before the turbo, but I'm not bothering doing it in the manifold. Just going to be in the dump pipe.
  • Moar Powar Babeh
  • Member For: 19y 4m 27d
Just to keep an eye on things, good way to know if its running lean etc, i know that heat is the main killer of these engines. Can never be to careful!
Second only to an actual wideband afr gauge.
