Fpv Vin For Spare Parts
velocityxr6t
  • Member For: 16y 2m 30d
Gentlemen,
I have a set of 6 pot brembos that I need some replacement mounting bolts for. After searching high and low it appears about the only place I can get them is from ford. And yeah, I need a vin number for bolts.....
TLDR need a 6 pot factory car vin number to purchase replacement bolts.If anyone feels generous and would lend me there number I'd very much appreciate it.
  • Member For: 16y 6m 26d
Gentlemen,
Sent mine through...
VINs can be found on auction sites easily enough.
Description: 12/07, Ford Performance Vehicles, F6 Typhoon, BF Mk II R Spec, Sedan
Colour: Black
Transmission: Manual
Engine: Petrol
Registration: No Registration
GST Status: GST Included in Sale Price
WOVR Status: Statutory Writeoff
VIN: 6FPAAAJGSW7P43580
http://www.pickles.com.au/damaged-salvage/item/-/details/CP-12-07--Ford-Performance-Vehicles--F6-Typhoon--BF-Mk-II-R-Spec--Sedan/202401504
Not the average engine bay:
http://picklescdn.cachefly.net/getPublicStockImage%3Fid=4918834
If anyone has seen my Tornado threads and is thinking that they’d also like to have an FPV ute project, then here’s one for you:
http://www.pickles.com.au/damaged-salvage/item/-/details/CP-05-05--Ford-Performance-Vehicles--F6-Typhoon--Utility-Extended-Cab/252431148
Or, maybe not.
Edited by PhilMeUp
Cheers Phil. Legend. I did check carsales but they don't openly show them anymore. Didn't remember seeing them on Pickles until you mentioned it.
Ralph,
If they're m12x70x1.5 socket cap head full thread from a brembo setup I'll take em.
Edited by velocityxr6t
  • Moar Powar Babeh
  • Member For: 19y 4m 20d
We'll I can tell you they aren't 15mm pitch they are finer than that.
Wasn't offering them for sale nearly measurement sake.
Ford price (if available available) will make your eyes bleed
Do you mean the bolts that attach the caliper to the car?
ie the ones labelled 15mm - they are used on standard and Brembo calipers. Get some from a wreck if you don't have your previous ones:
BF_Falcon_Front_Bearing_Hub_06_18_4_2014
or the smaller ones that are on standard calipers?
BF_Falcon_Front_Bearing_Hub_05_18_4_2014
No, I'm talking about the ones that mount the caliper to the bracket. Not the bracket to the spindle.
Ah. These ones?
From: http://www.fordxr6turbo.com/forum/topic/90499-photo-essay-swapping-brembo-calipers-between-babf-and-fg/?hl=fg+bracket.#entry1543939
While the bolts were out I measured them. The threads are 70mm long, the width is M12 and the thread is a 1.5.
I posted some bolt dimensions for 4 piston Brembo calipers as well a while ago:
http://www.fordxr6turbo.com/forum/topic/90508-photo-essay-rebuilding-brembo-calipers
