rokkie Member 87 Member For: 12y 3m 4d Gender: Male Location: Adelaide, SA Posted 08/11/15 09:08 AM Share Posted 08/11/15 09:08 AM Hi all, I was wondering how much the oil flow rate to the turbo should be? I'm getting 1L a minute. The bloke who rebuilt the turbo said I should be getting at least 2L a minute. It's the standard gt3582 with a genuine Garrett core. I checked the flow rate with a cold engine and no turbo bolted up (didn't want to run the turbo with no oil supply). The viscosity of the oil is 15w/40. I have also removed the ford filter in the banjo fitting.Thanks in advance.Sent from my SM-N910G using Tapatalk Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 3m 1d Gender: Male Location: Perth Posted 08/11/15 09:23 AM Share Posted 08/11/15 09:23 AM Is that with or without the restrictor in place? 2ltrs a min seems excessive to me. Link to comment Share on other sites More sharing options...
rokkie Member 87 Member For: 12y 3m 4d Gender: Male Location: Adelaide, SA Posted 08/11/15 10:04 AM Author Share Posted 08/11/15 10:04 AM The only restrictor I knew about was in the core. If you talking about the inlet flange bolt which the braided line connects too. I tested it with that connected. I did drill out the ID to around 5mm. I'm agree that 2L does seem excessive. Good old mate Google recons 1 - 1.5L a minute is what should be supplied. Thought I'd ask the guru'sSent from my SM-N910G using Tapatalk Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 1m 27d Gender: Male Location: Perth Posted 08/11/15 02:46 PM Share Posted 08/11/15 02:46 PM The line will provide more oil than the restrictor can flow. Turbo needs very little oil Link to comment Share on other sites More sharing options...
rokkie Member 87 Member For: 12y 3m 4d Gender: Male Location: Adelaide, SA Posted 09/11/15 03:03 AM Author Share Posted 09/11/15 03:03 AM That's what I was thinking. CheersSent from my SM-N910G using Tapatalk 1 Link to comment Share on other sites More sharing options...
RaceEquipped Member 52 Member For: 9y 11d Gender: Male Posted 13/12/15 02:13 AM Share Posted 13/12/15 02:13 AM 2L sounds excessive. 1L sounds about right. Link to comment Share on other sites More sharing options...
