  • Member For: 12y 7m 5d
Hi all, I was wondering how much the oil flow rate to the turbo should be? I'm getting 1L a minute. The bloke who rebuilt the turbo said I should be getting at least 2L a minute. It's the standard gt3582 with a genuine Garrett core. I checked the flow rate with a cold engine and no turbo bolted up (didn't want to run the turbo with no oil supply). The viscosity of the oil is 15w/40. I have also removed the ford filter in the banjo fitting.
Thanks in advance.
Sent from my SM-N910G using Tapatalk
https://www.fordxr6turbo.com/forum/topic/91359-oil-flow-rate-to-turbo/
  • Moar Powar Babeh
  • Member For: 19y 7m 2d
Is that with or without the restrictor in place?
2ltrs a min seems excessive to me.
The only restrictor I knew about was in the core. If you talking about the inlet flange bolt which the braided line connects too. I tested it with that connected. I did drill out the ID to around 5mm.
I'm agree that 2L does seem excessive. Good old mate Google recons 1 - 1.5L a minute is what should be supplied. Thought I'd ask the guru's
  • Dropping a turd
  • Member For: 17y 5m 29d
The line will provide more oil than the restrictor can flow. Turbo needs very little oil
  • 1 month later...
