New Purchase/Build - Home Renovations - Gardens - Garages & Sheds.
Pixy Angel
  • Member For: 17y 4d
There is only one lighting circuit
Apparently all new homes are suppose to have half the lights on one RCD
And the other half on another RCD
He is bringing a copy of the regs. to work tomorrow and show me
It's not unsafe, just not right
  • Member For: 11y 1m 26d
Don't have a wiring rules on me an haven't looked at one in a long time but if I remember light are considered 0.5A when calculating the load for a circuit. So 10A CB would be around 20 lighting points.
Something a lot of sparky's do these days when building new houses is only install a single 413 plug in the roof because of owners wanting to put there own down lights in which is easy for the sparky there max demand and circuit loading works out less because they only have to count it as 1 point. Then later the owner go to put there down light in and daisy chain more 413 outlet off the first and fit extra lights everywhere.
Edit: extraction fans and ceiling fans are also lighting points.
He said it's something to do with if you blow a circuit at night it's so you still half of your roof lights working...
He said when his house was built, they did the same... Made them come out and fix it because he had a copy of the wiring rules to prove it
I'll put a copy up when he gives it to me
  • Member For: 17y 1d
Interesting, better check our fuse box.
I checked ours and only see lights written on one fuse as well.
I know RCD is residual current device, that stops you dying if you stick a fork in the socket, and we have a power point at the water tank (Tank P-Pt), AC is obvious too.  HWS= hot water system, Oven...but what are the N1/2/3 and different "power" items?
What does it all MEAN
  • Member For: 11y 8m 30d
Secret sparky business mate nothing you need to worry about, n is just neutral. Just info for future sparkies. Power 1 etc is just numbers of separate power circuits.
  • Like 2
That's exactly what I expected your illuminati overlords would tell you to say.
Lol secret sparky buisness. The n1,n2n3 are just labelling of were the neutral of that circuit is terminated on the bar. Don't remember every seeing seperate lighting circuit being required but you may also have another set of rules on the east coast like we have here with our WA electrical requirements.
