Carbon Fibre Parts Wish List
HI PSI
  • Sandtrap Motorsport
  • Member For: 16y 1m 16d
Sending away to China to get made in bulk ? (Nothing wrong with that, they do top work)
Or is it Aus based?
I'm wondering due to chasing some dry carbon sheets in future
  • Moar Powar Babeh
  • Member For: 19y 3m 18d
I'm considering making carbon fibre parts and I would like to get feedback on what parts you would like to see. All parts will be vacuum formed with quality being the highest priority. At this point in time I will be using a 204 gram 2x2 weave cloth.
Fire away.....
(B series)
Rad closure panel
Battery side Air boxes
4" intake Tubes
  • Member For: 18y 7m 16d
Or is it Aus based?
I will be making the parts myself. I will be using resin infusion, but I have access to whatever you want or need. :-)
ICC facia, console, door inserts B series.
The facia panel would be relatively easy to make. Cutting the slots for the button on a high series would be the challenge... I'm game to give it a go....
Console ?? Interesting!!! I will source one from a wrecker and assess the complexity.
Door inserts? Are you referring to the spears? Or the sections in the handles?
Edited by HI PSI
Tail shaft;)
With how many ponys your going to have not a bad idea.
Anything that can take weight off the car would help. Bonnet, boot ect.... what the budget?
Also if you want make 2 of everything and I test the seconds for you for free. :D
Tail shaft is a bit out of my capability, as it is a totally different process and requires specialised machinery.
Guards, bonnets, skirts, spoilers etc. can be done relatively easily and is on my ajenda. I will also look further into lip spoilers as I get time....
NA style coil cover would be tops, no holes like the turbo cover. Larger holes to clear AN breather fittings would also be good.
What size fitting are you thinking of using?
  • Member For: 11y 1m 21d
Let me know if you want a g6e lip spoiler to make a mould of or something for anybody that may want one, mine is off atm and they are impossible to get off without ruining the boot. Once it goes on my new boot it wont be coming off again...
Pics of old boot(which already had accident damage)
Same amount of sika that holds a bloody windscreen in....
Edited by barnz
(B series)
Rad closure panel
4" intake Tubes
Radiator closure panel would be easy. I saw another thread somewhere where they requested that the tongues be extended. Would you want the same modification?
Battery side air box would be relatively easy also. I will however need some pics of a another aftermarket setup, so that I can see what other components are in the area. The only problem that I can foresee, would be sourcing a silicon hose like the Process West unit. ... Not impossible, and may be on the cards....
4' inatke tubes.... I was looking into these myself, for my own car. My mate (Supplier) told me that the carbon sock is ridiculously priced. For this reason, I think it will not be practical.
