Dump And Cat - Venom Vs Xforce
Krazy Kyle
  • 1 month later...
  • Sandtrap Motorsport
  • Member For: 16y 3m 23d
Here's my solid opinion and being that I've used both a few times id say it's worthy
The x-force is a dump and cat.... Derr but the quality is minimal plain n simple, had to spot weld dump sections many times for holes not to long after new and cat sections have very well been known to collapse
The venom is a quality stainless bolt up cat section so fits from the base of the dump to the cat back section
Flows amazing,sounds stock and is brilliant quality
If you're going for the mod path where it only requires a cat replaced go the venom every day
If u need a full exhaust go SMB or manta hahaha
is there a trick to getting the Venom to seat & seal nicely on the cast dump ?
no matter what I do, there is always a slight leak ...
cat was fitted new, but now is sub 5,000km old
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 9m 17d
If it got fitted dump first and tightened up it could of bent the flange section as there's no defined "home" almost a rough location
Those FG flange style sections are crappy as so I'm not sure how you went about it but I always 50% it at that flang then bolt the cat back on
Then 100% the flange
Works 60% of the time everytime lol
But yeh you probably have a dent within the flange flare section on the venom now that u might have to panel beat flush again
luke - im almost thinking changing to a non-olive joint-style flange dump, just for ease
pretty sure that is the case ... ill get the hammer out :) cheers !
