Dump And Cat - Venom Vs Xforce
Krazy Kyle
  • Get It To Wheelspin Uncontrolably Then Give It Another 5 Pounds
  • Cruise Control
  • Member For: 14y 4m 25d
Tried not to start a new thread, but cannot find the comparison info im after. And yes, just dump and cat, not after a full exhaust.
Can anyone tell me their experience with this mod? flow rates, issues with waste-gate and the piping etc?
  • Cruise Control
that's my thought but ive read in some older threads that the venom was smaller... but 4" dump and 5" cat is a 4" dump and a 5" cat.... is what it is. Plus they were 3 or 4 year old comments. the new ones seem pretty good. I was more curious to the flow of each.
or any other brand for that matter
Edited by Krazy Kyle
  • Member For: 11y 9m 21d
huh....since when does venom make a DUMP for the FG?
AFAIK I thought it uses stock dump (3.5" ?) and then when going the 4" xforce you need to do rear housing mod? (especially on the F6 turbo).
Also not 100% but a catpipe I bought a while ago - guy had to make the OEM pipe longer to suit the xforce catback (had cat welded in and slightly extended and widened the OEM piping to match 3.5" xforce catback). Not sure if that was due to old design....or whether it still occurs in xforce systems?
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 9m 15d
Here's my solid opinion and being that I've used both a few times id say it's worthy
The x-force is a dump and cat.... Derr but the quality is minimal plain n simple, had to spot weld dump sections many times for holes not to long after new and cat sections have very well been known to collapse
The venom is a quality stainless bolt up cat section so fits from the base of the dump to the cat back section
Flows amazing,sounds stock and is brilliant quality
If you're going for the mod path where it only requires a cat replaced go the venom every day
If u need a full exhaust go SMB or manta hahaha
  • Like 3
  • Cruise Control
thankyou Jet, appreciate the input. I wanted to head that direction, now im sure
  • 4 weeks later...
  • Cruise Control
just pulled 333rwkw with the venom cat/dump. pretty happy. cheers Jet.
  • Like 2
