  • Member For: 20y 9m 7d
Hi fellow members ,just wondering how the FPV FG r spec launch control works ?
Is it purely ECU controlling torque , is it a separate module ? , is this feature available through the Ford spare parts dept ?,
Im sure this would be handy addition to launch my FPV F6,auto off the line , other turbo fans may also be interested in a group buy lol ,thanks in advance
https://www.fordxr6turbo.com/forum/topic/91259-launch-control-how-does-it-work/
  • 3 weeks later...
  • To Loud
  • Member For: 13y 4m 15d
thanks for verifying, well since we are on the topic, how does it work.
I have attempted several times to get this to work, with little success.
I think I have got it to work maybe once or twice.
I think it might be the fact that I mash the go fast pedal after I release the clutch.
Maybe I should wait a bit more and then mash the go fast pedal.
  • 6 years later...
  • Member For: 15y 2m 22d
Both the manual & automatic version have it.
Manual: first gear, clutch in & full throttle - engine will spin up to 3,000 RPM. Release clutch & enjoy the ride.
Automatic: Trans in neutral & full throttle - engine will spin up to 3,000 RPM. Pull trans into D & enjoy the ride.
Both versions: traction control intervenes & prevents massive tyre smoking &  hopefully, no drivetrain damage.
I wouldn't do it too often, as the diff mounting bushes will eventually fail.
  • WOT?
  • Moderating Team
  • Member For: 12y 1m 21d
Expand
edit: I don't think there's a launch control on the auto's, just a cut-off if you stall it up for too long (can be edited out)
  • Puff
  • Member For: 10y 2m 17d
You can switch it on for autos in the tune. You need to use PCMTec to do this and it needs to be set up a little differently, due to the trans having load in gear vs the manual working in neutral. Haha I do not recommend revving your car and slamming it into drive, however much maximum respect you gain from doing so.
