Btr - Reverse Issues When Hot
Tocchi
  • Sandtrap Motorsport
  • Member For: 16y 1m 5d
Bit of a head scratcher, for me at least, I've come to conclusion of cuntsf*cked.
BA BTR 4spd, recently installed into BF. Running air trans cooler.
1-2-3-4 = work fine in tiptronic and D mode.
4th works,
4th gear kickdown works,
1st gear engine braking works
Reverse = works fine when COLD
When WARM, it needs about 2,000rpm over 3 seconds, back off throttle slightly, and then reverse engages with a big thud.
When HOT, it needs about 4,000rpm over 3 seconds, back off throttle slightly, and then reverse engages with a big thud.
Trying to work out if it is a:
Line pressure issue
Low fluid in transmission
Reverse input clutch
Anybody have an idea ?
  • Member For: 16y 5m 14d
Serves you right for not going with a ZF.
Make amends.
Make amends.
aren't you having issues with the ZF's in your vehicles? :P
^^^lol
Tocchi I know it doesn't really help but someone else has felt your reverse pain... see post #124 in this thread
http://www.fordxr6turbo.com/forum/topic/84229-the-fluid-change/
Great thread to dump it in
Don't use reverse when hot, that's a fix
I have been using this solution
Pfffft.
Only having ZF issues in one of the vehicles.
The other one doesn't go because of a P0121 error code that I can't figure out.
Get yer facts straight.
Meanwhile, I'm using a 527,000km ex-taxi.
Sigh.
(It seems that the troublesome green one has now infected the previously-reliable blue one.)
  • 3 years later...
  • Member For: 6y 1m 11d
4th works,
Line pressure issue
Sorry to bring up an old thread, my car is doing the same thing, did you ever work out what it was.
