Jason87 Member 37 Member For: 12y 9m 25d Posted 23/09/15 08:16 AM Share Posted 23/09/15 08:16 AM Ok I no its usual for the timing cover to leak due to the bolts being to long Jst wanting some advice from ppl who hav tackled the problem more so what needs to be removed to get to all the bolts are they all to long an will it need a new seal I've got a oil change coming up but sort of dnt want it to be a all day mission so any advice I'll take onboard cheers Link to comment https://www.fordxr6turbo.com/forum/topic/91180-fg-xr6t-leaking-timing-cover-repair/ Share on other sites More sharing options...
wtf22 New Member 11 Member For: 13y 29d Gender: Male Location: Noosa Posted 23/09/15 08:33 AM Share Posted 23/09/15 08:33 AM mine is a ba series 1, rocker cover off and fans out, pull the balancer, and take off the belt tensioner and idler,mine has a seal but I understand the later motors have a chemical seal (goop) but I would replace the rocker cover gasket and plugtube seals at the same time.The balancer will need a special puller to get off so make sure you have access to one firstCheers Jay Link to comment https://www.fordxr6turbo.com/forum/topic/91180-fg-xr6t-leaking-timing-cover-repair/#findComment-1562902 Share on other sites More sharing options...
Jason87 Member 37 Member For: 12y 9m 25d Posted 23/09/15 08:43 AM Author Share Posted 23/09/15 08:43 AM Yer got access to the puller I'm glad the radiator stays in but dirty on taking the engine cover off I not long did that to 2pac it FML cheers Link to comment https://www.fordxr6turbo.com/forum/topic/91180-fg-xr6t-leaking-timing-cover-repair/#findComment-1562907 Share on other sites More sharing options...
wtf22 New Member 11 Member For: 13y 29d Gender: Male Location: Noosa Posted 23/09/15 08:47 AM Share Posted 23/09/15 08:47 AM I pulled my rad to flush it at the same time but I don't think it needs to be pulled Link to comment https://www.fordxr6turbo.com/forum/topic/91180-fg-xr6t-leaking-timing-cover-repair/#findComment-1562908 Share on other sites More sharing options...
crazyxa Member 84 Member For: 18y 3m 8d Posted 01/10/15 11:30 AM Share Posted 01/10/15 11:30 AM (edited) What is the best way to loosen and tighten the crank pulley bolt on a ZF equipped auto FG?Is it like the BTR auto where you remove the transmission bell housing inspection plate or is there a port to lock the drive plate / flywheel with a large flat head?Then breaker bar and some shoulder. Same to tighten also? Edited 01/10/15 11:31 AM by crazyxa Link to comment https://www.fordxr6turbo.com/forum/topic/91180-fg-xr6t-leaking-timing-cover-repair/#findComment-1563792 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 8m 28d Gender: Male Location: Perth Posted 01/10/15 11:54 AM Share Posted 01/10/15 11:54 AM There is a small inspection cover (the same one used to remove the TC to Flexplate bolts) you could use or just pop the start off and use a small piece of angle iron the lock the flexplate. Link to comment https://www.fordxr6turbo.com/forum/topic/91180-fg-xr6t-leaking-timing-cover-repair/#findComment-1563795 Share on other sites More sharing options...
barnz Member 3,047 Member For: 11y 7m Gender: Male Location: Brisbane Posted 01/10/15 10:25 PM Share Posted 01/10/15 10:25 PM Breaker bar wedged against the ground, hit the key. Job done lolDont do that.... Link to comment https://www.fordxr6turbo.com/forum/topic/91180-fg-xr6t-leaking-timing-cover-repair/#findComment-1563821 Share on other sites More sharing options...
jas98 Member 1,049 Member For: 12y 10m 28d Gender: Male Location: Maryborough Qld Posted 02/10/15 12:09 AM Share Posted 02/10/15 12:09 AM Does ba xr6t have a seal for timing cover? I was told that they don't and its the fg has a seal. How long would it take to change? Link to comment https://www.fordxr6turbo.com/forum/topic/91180-fg-xr6t-leaking-timing-cover-repair/#findComment-1563837 Share on other sites More sharing options...
jas98 Member 1,049 Member For: 12y 10m 28d Gender: Male Location: Maryborough Qld Posted 02/10/15 12:09 AM Share Posted 02/10/15 12:09 AM Does ba xr6t have a seal for timing cover? I was told that they don't and its the fg has a seal. How long would it take to change? Link to comment https://www.fordxr6turbo.com/forum/topic/91180-fg-xr6t-leaking-timing-cover-repair/#findComment-1563838 Share on other sites More sharing options...
crazyxa Member 84 Member For: 18y 3m 8d Posted 02/10/15 08:41 AM Share Posted 02/10/15 08:41 AM On 02/10/2015 at 12:09 AM, jas98 said: Does ba xr6t have a seal for timing cover? I was told that they don't and its the fg has a seal. How long would it take to change?All depends on how long it takes you to remove the crank bolt and pulley. With the right tools probably 2hrs max. Someone who does them all the time even less. Note I am assumeIng the timing cover does not need to be removed to remove the front crank seal. Link to comment https://www.fordxr6turbo.com/forum/topic/91180-fg-xr6t-leaking-timing-cover-repair/#findComment-1563946 Share on other sites More sharing options...
