k31th less WHY; more WOT Site Developer 28,953 Member For: 16y 7m 8d Gender: Male Location: Melbourne Posted 13/11/18 12:41 AM Share Posted 13/11/18 12:41 AM yes, you undo/loosen the transmission mount and then jack the engine from the front of the oil pan with something that'll give a little between the jack and the sump (soft wood etc). Nah, the engine mounts themselves allow a bit of rotation, so don't need to be loosened. Link to comment Share on other sites More sharing options...
BUTTERSFGF6 New Member 6 Member For: 6y 5d Posted 13/11/18 12:56 AM Share Posted 13/11/18 12:56 AM Thanks heaps mate ill let you know how I go. Im dojng this on my fpv fg f6 but their all the same really. So far ive taken exhaust n tail shaft out n cracked all the bolts besides the top few. On the bottom bolts that ive cracked that hold box n to sump they are leaking coilent is this normal. Ill tey work out to add pic of it to show you Link to comment Share on other sites More sharing options...
BUTTERSFGF6 New Member 6 Member For: 6y 5d Posted 13/11/18 05:20 AM Share Posted 13/11/18 05:20 AM Hey dobuse know how much oil the gearbox would hold cheers Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,953 Member For: 16y 7m 8d Gender: Male Location: Melbourne Posted 13/11/18 07:11 AM Share Posted 13/11/18 07:11 AM https://www.fordxr6turbo.com/forum/topic/88819-zf-transmission-fluid-change/ that thread should have the details you need Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 5m 18d Gender: Male Location: Adelaide Posted 13/11/18 08:28 AM Share Posted 13/11/18 08:28 AM Drop the trans mount, this will automatically lift the front of the engine and lower the rear of the trans, long extension bars (x2) and uni joint,19mm shallow socket and take it up from the trans mount area and up towards the top of the bellhousing, rattle gun or ratchet and away you go. Now you HAVE TO undo the torque converter bolts FIRST, this is done by taking out the starter motor, using a mirror ( if doing this without a hoist ) and undoing the x4 bolts once you’ve undone the torque converter bolts then tackle the bell housing bolts, then pry the trans away gently from the engine block... making sure the whole time the converter is being pushed back into the transmission ( through the starter motor hole ) the whole time as you want the converter to stay in the transmission as you lower the transmission down from the transmission tunnel. It will all make sense as you're doing it 1 Link to comment Share on other sites More sharing options...
