Vallidium Member 26 Member For: 11y 4m Gender: Male Posted 16/09/15 03:42 AM Share Posted 16/09/15 03:42 AM Hi all, had a quick look but couldn't find what I was after, has anyone done a tutorial or one of the awesome photo essay threads like Phil does on the removal and replacement of the zf gearbox ? I want to have a go myself but obviously this would make life a lot easier for me especially as I'll be doing it without a hoist ! Any help/advice is appreciated ! Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 4m 7d Gender: Male Location: Perth Posted 16/09/15 03:55 AM Share Posted 16/09/15 03:55 AM It's really a case of support the trans with a suitable jack, remove everything between it and the car and then remove. Keep it nose up so the Torque Convertor stays in place in the trans.ZF6hp Workshop manual attached. The last section covers trans removal.307-01bZF 6HP26.pdf Link to comment Share on other sites More sharing options...
turboknapp Donating Members 783 Member For: 17y 10m 6d Gender: Male Location: perth w.a Posted 16/09/15 04:37 AM Share Posted 16/09/15 04:37 AM Make sure you got a good hold with the jack, don't want it slipping off Link to comment Share on other sites More sharing options...
Robos F6 Donating Members 407 Member For: 15y 10m 28d Gender: Male Location: Vic Posted 16/09/15 05:13 AM Share Posted 16/09/15 05:13 AM I used 2 jacks last time, actually the job isnt that bad at all. Link to comment Share on other sites More sharing options...
Vallidium Member 26 Member For: 11y 4m Gender: Male Posted 22/09/15 08:04 AM Author Share Posted 22/09/15 08:04 AM Thanks for the help gents appreciate it ! Link to comment Share on other sites More sharing options...
BUTTERSFGF6 New Member 6 Member For: 6y 2m 17d Posted 13/11/18 12:09 AM Share Posted 13/11/18 12:09 AM Any tips on cracking the top few bolts from gearbox to the engine its self I got car on stands and its a c**t to try get to these top 2 bolts Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,181 Member For: 16y 9m 20d Gender: Male Location: Melbourne Posted 13/11/18 12:10 AM Share Posted 13/11/18 12:10 AM jack up the front of the engine so that it rotates a little bit which gives you cleaner access to the top bolts. Link to comment Share on other sites More sharing options...
BUTTERSFGF6 New Member 6 Member For: 6y 2m 17d Posted 13/11/18 12:12 AM Share Posted 13/11/18 12:12 AM What once I got the other bolts out already? Sorry I dont know much todo with cars I just keen todo this my aelf n learn im replacing rear main seal. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,181 Member For: 16y 9m 20d Gender: Male Location: Melbourne Posted 13/11/18 12:30 AM Share Posted 13/11/18 12:30 AM just put one or two of the bottom bolts back in so that it stays pushed hard against the engine then do what I said in my last post Link to comment Share on other sites More sharing options...
BUTTERSFGF6 New Member 6 Member For: 6y 2m 17d Posted 13/11/18 12:36 AM Share Posted 13/11/18 12:36 AM Thank you where do you recon is safe to jack the engine from and when I do this will the engine n box both rotate a little bit? So I dont have to undo the engine mounts or anything sorry rather ask questions than ausemee n screw it Thanks appreciate the help Link to comment Share on other sites More sharing options...
