norrs Donating Members 448 Member For: 17y 11m 7d Gender: Male Location: Darwin Posted 15/09/15 08:17 AM Share Posted 15/09/15 08:17 AM Hi guys, ford have said my tail shaft centre bearing is worn and the rubber is split.They want $1630 to fix itThe car has only done 90,000kmAnyway three questions:1. I have an auto - how hard is this to do myself 2. Do I or should I replace the uni joint at the same time - can I do that myself3. I have 367rwkw should I be replacing them with oem parts or is there something better to useI do recall changing my uni joint on my Datsun about 20 years ago but I can't recall how hard it was with normal tools Link to comment https://www.fordxr6turbo.com/forum/topic/91148-tailshaft-centre-bearing/ Share on other sites More sharing options...
bamk2f6tornado Bronze Donating Members 777 Member For: 11y 6m 26d Gender: Male Location: Rockhampton Qld Posted 15/09/15 08:34 AM Share Posted 15/09/15 08:34 AM (edited) Ford have a habit of wanting to replace the whole tailshaft. Your not the first bloke they have tried to do this on. If it is just the centre bearing that needs replacing it is a fairly easy job and can be done with basic hand tools. There is a very detailed thread on here somewhere with pics and everything that makes the job super simple. Would only take a mechanic an hour or 2 if you not comftable having a stab yourself. Edited 15/09/15 08:35 AM by bamk2f6tornado Link to comment https://www.fordxr6turbo.com/forum/topic/91148-tailshaft-centre-bearing/#findComment-1561711 Share on other sites More sharing options...
norrs Donating Members 448 Member For: 17y 11m 7d Gender: Male Location: Darwin Posted 15/09/15 08:53 AM Author Share Posted 15/09/15 08:53 AM Ok I found this and will have a read http://www.fordxr6turbo.com/forum/topic/90417-centre-bearing-replacement/?hl=centre+bearingSorry I did a search on my phone app and it didn't find what I was looking for but my PC was better Link to comment https://www.fordxr6turbo.com/forum/topic/91148-tailshaft-centre-bearing/#findComment-1561717 Share on other sites More sharing options...
Wilko16 Donating Members 1,672 Member For: 17y 7m 8d Gender: Male Location: Melbourne Posted 15/09/15 08:55 AM Share Posted 15/09/15 08:55 AM Some times it is not an easy job! Some times the uni can not be removedGo get some quotes from driveline shops Should be able to get an even stronger shaft for half that price What state are you in? Link to comment https://www.fordxr6turbo.com/forum/topic/91148-tailshaft-centre-bearing/#findComment-1561718 Share on other sites More sharing options...
norrs Donating Members 448 Member For: 17y 11m 7d Gender: Male Location: Darwin Posted 15/09/15 08:58 AM Author Share Posted 15/09/15 08:58 AM Darwin Mate. my tuner did mention a while back that I should look into a stronger tailshaft as it may be the next weak link. I also have an upgraded ZF. yeah I'll call around and see what their quotes are Vs Ford. I see it needs to be rebalanced after the change so I suppose I should take it to a shop. Link to comment https://www.fordxr6turbo.com/forum/topic/91148-tailshaft-centre-bearing/#findComment-1561720 Share on other sites More sharing options...
Wilko16 Donating Members 1,672 Member For: 17y 7m 8d Gender: Male Location: Melbourne Posted 15/09/15 09:05 AM Share Posted 15/09/15 09:05 AM I had my centre bearing replaced, retubed and bigger uni installed with new yokes for $700So definitely shop around 2 Link to comment https://www.fordxr6turbo.com/forum/topic/91148-tailshaft-centre-bearing/#findComment-1561722 Share on other sites More sharing options...
PTR_NITRO_FG Donating Members 3,214 Member For: 12y 1m 4d Gender: Male Location: NOR Perth Posted 16/09/15 02:22 AM Share Posted 16/09/15 02:22 AM ^^^ FG right? My Ford said there was no part number just to buy the centre bearing on its own (for the FG) LOL I didn't care anyways cause got whole tailshaft replaced and balanced by them under aftermarket warranty (think the job was around $1800 so OP is probably quoted a whole new tailshaft).But yeh Norrs if you're paying for it; may as well go upgraded for piece of mind? At over 360rwkw, you will probably need tailshaft eventually (then ZF auto rebuild, stronger CV's and probably other stuff too)....apparently people have seen this stuff break at 350rwkw (but most are happy to risk it if they have 360-390rwkw). 1 Link to comment https://www.fordxr6turbo.com/forum/topic/91148-tailshaft-centre-bearing/#findComment-1561823 Share on other sites More sharing options...
PhilMeUp Member 1,045 Member For: 16y 11m 13d Gender: Male Location: Perth, Western Australia Posted 16/09/15 06:28 AM Share Posted 16/09/15 06:28 AM On 15/09/2015 at 8:17 AM, norrs said: 1. I have an auto - how hard is this to do myself2. Do I or should I replace the uni joint at the same time - can I do that myself3. I have 367rwkw should I be replacing them with oem parts or is there something better to use1) I've done the job three times on utes, but they are a CV joint and much easier to pull apart than a universal joint. There are photos of each job in my Tornado threads:http://www.fordxr6turbo.com/forum/topic/89684-2006-fpv-tornado-f6-ute-cleanup-resurrection/page-2#entry1521879http://www.fordxr6turbo.com/forum/topic/90489-2007-fpv-tornado-ute-tinkering-setup/page-2#entry15511542) My understanding is the the universal joint usually requries replacing at the same time, but not always. If you've got the time and resources then remove the tail shaft and get the universal joint checked. I'd be surprised if it needs replacing after 90,000km.3) I've used centre bearings from Hardy Spicer - http://www.hardyspicer.com.au Doesn't look like they have a branch in Darwin, but call head office and see if they can refer you to someone there. There's no reason why you can't get a Hardy Spicer bearing sent to you and have a local workshop fit it for you. A taxi workshop would be the cheapest place. Link to comment https://www.fordxr6turbo.com/forum/topic/91148-tailshaft-centre-bearing/#findComment-1561902 Share on other sites More sharing options...
PTR_NITRO_FG Donating Members 3,214 Member For: 12y 1m 4d Gender: Male Location: NOR Perth Posted 16/09/15 07:37 AM Share Posted 16/09/15 07:37 AM Hey Phil....where are these 'taxi workshops' you speak of in Perth? Any NOR and are they just operated by mechanics who offer taxi drivers cheap hourly rates or something? Link to comment https://www.fordxr6turbo.com/forum/topic/91148-tailshaft-centre-bearing/#findComment-1561917 Share on other sites More sharing options...
PhilMeUp Member 1,045 Member For: 16y 11m 13d Gender: Male Location: Perth, Western Australia Posted 16/09/15 08:01 AM Share Posted 16/09/15 08:01 AM I deal with Steve at Bianca Automotive - 122 Angove Street, North Perth.There's actually a 24hr callout guy these days, $50 callout fee and $50 for the first look - 0435 078 682.I recently found a place at 86 Beechboro Road, Bayswater. Guy called Angelo. Knows lots about Falcons. 0412 124 902There's Metro Taxi Management in Morley. I deal with a guy there called Rio sometimes. Basically, taxi mechanics deal with Falcons all the time, so they know them very, very well. It's all about getting the job done fast and cheap. They won't know anything about turbo stuff, but everything else on the car is basic Falcon XT stuff, ie bearings, etc. Link to comment https://www.fordxr6turbo.com/forum/topic/91148-tailshaft-centre-bearing/#findComment-1561925 Share on other sites More sharing options...
