JVK Silver Donating Members 751 Member For: 18y 11m 25d Gender: Male Location: North West Hot Hell,VIC Posted 18/09/15 11:30 PM Share Posted 18/09/15 11:30 PM ^^^^^^ This guy is right. That is what you engine is going to look like if not already.By how I read it you are doing things all arse about. Do not drive this vehicle and get hold of a good tuner in your area and go threw with him what you have done.He may want to slap you around a little but in the end will be able to get your car sorted.There are plenty of threads on this site about doing things the right way and in the right order, You just have to search and read.Any other ways usually end up in engine failure and tears ! Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,036 Member For: 9y 7m 21d Gender: Male Location: Canberra ACT Posted 19/09/15 12:41 AM Share Posted 19/09/15 12:41 AM I agree it sounds like there are a lot of factors here and a professional look over would be a good idea. I'm stock and haven't made any recent repairs etc , so my trouble shooting is a bit simpler. Those boost pressures might just be a faulty gauge - mine had a cheap one in it when I got it and shows 15psi under full load which is clearly wrong. New one going in next week. Sent from my SM-N9005 using Tapatalk Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 6m 16d Gender: Male Location: @ my laptop Posted 19/09/15 03:46 AM Share Posted 19/09/15 03:46 AM which capa flash box do you have? Link to comment Share on other sites More sharing options...
Barbwire 57 New Member 14 Member For: 9y 3m 13d Posted 19/09/15 03:21 PM Author Share Posted 19/09/15 03:21 PM Thanks JVK And andrew again all advice taken. And Ratter I think its a capa 1 Link to comment Share on other sites More sharing options...
Barbwire 57 New Member 14 Member For: 9y 3m 13d Posted 19/09/15 03:42 PM Author Share Posted 19/09/15 03:42 PM And bamk2 understood enough said... nice knock knock illustration Link to comment Share on other sites More sharing options...
JVK Silver Donating Members 751 Member For: 18y 11m 25d Gender: Male Location: North West Hot Hell,VIC Posted 19/09/15 10:59 PM Share Posted 19/09/15 10:59 PM Make sure the boost guage is plumbed into an inlet manifold source ( at the back around the fuel pressure reg area) and not the turbo side oryou will get incorrect psi readings. Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 6m 16d Gender: Male Location: @ my laptop Posted 20/09/15 02:53 AM Share Posted 20/09/15 02:53 AM if you have a capa 1 it limits your choice who can tune it if you want to use that box, only Capa or a tuner with a very old and not updated software can do it Link to comment Share on other sites More sharing options...
Barbwire 57 New Member 14 Member For: 9y 3m 13d Posted 20/09/15 07:11 AM Author Share Posted 20/09/15 07:11 AM Thanks JVK that's why such a high reading then because I do have it in the wrong spot I've got it tea PC into the actuator line Link to comment Share on other sites More sharing options...
_Velocity_ Bronze Donating Members 2,768 Member For: 13y 7m 18d Gender: Male Location: Victoria Posted 21/09/15 01:28 PM Share Posted 21/09/15 01:28 PM Dude. These aren't VL turbos. Manual boost controllers don't work in Fords. Xtreme Ford TuningNumber 33, Unit’s 1 & 2 Elmsfield Rd,Midvale. WA. 6065P: (08) 9250 8266F: (08) 9250 7796Go see them before you need to replace an engine. Link to comment Share on other sites More sharing options...
Barbwire 57 New Member 14 Member For: 9y 3m 13d Posted 21/09/15 04:59 PM Author Share Posted 21/09/15 04:59 PM Understood thanks velocity. While ive got yous here opinion on gearboxes , stay with th 4 spd auto that is in the car , or fit the 6 speed manual that I have here , which is less likely to give dramas in the long run.? Or does it come down to personal choice Link to comment Share on other sites More sharing options...
