Maximus Member 1,627 Member For: 17y 10m 9d Gender: Male Location: Slip Sliding Away Posted 12/09/15 10:19 AM Share Posted 12/09/15 10:19 AM Hey Guys, Just took the dash out of a 2004 BA XR6 Turbo with Dual Zone climate to fix the mixer shaft that had broken in the passenger side.Got it all out easy enough, replaced the broken one, and replaced the drivers side just in case that is about to break too.Put it all back together, for some reason I have 2 screws left over. Not sure where they went but oh well. Took it for a drive around the block and now have some issues.1. The ICC has SECURITY CODE ALERT come up. I have read that this will fix itself and not to worry.2. All dash lights are on, including all warning lights, there is no speedo or revs working, doesnt say what gear you are in either.3. Noticed that the car seems to be stuck in 3rd gear. yes its an auto.I guess somewhere along the lines I have messed up.Anyone have any ideas BEFORE I take it all apart again tomorrow?Thanks in advance Link to comment Share on other sites More sharing options...
rokkie Member 87 Member For: 12y 4m Gender: Male Location: Adelaide, SA Posted 12/09/15 10:41 AM Share Posted 12/09/15 10:41 AM Money's on a connection. Sounds like a missing CAN signal. Double check the l/h side orange & white connector also the HIM module (vent controllet) Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 2m 24d Gender: Male Location: Perth Posted 12/09/15 11:02 AM Share Posted 12/09/15 11:02 AM Car is in limp mode. Sounds like those 2 screws are important. 1 Link to comment Share on other sites More sharing options...
Maximus Member 1,627 Member For: 17y 10m 9d Gender: Male Location: Slip Sliding Away Posted 12/09/15 08:56 PM Author Share Posted 12/09/15 08:56 PM Rokkie thanks for the quick reply.When you say the him module is that the one behind the ICC? Link to comment Share on other sites More sharing options...
Maximus Member 1,627 Member For: 17y 10m 9d Gender: Male Location: Slip Sliding Away Posted 12/09/15 09:40 PM Author Share Posted 12/09/15 09:40 PM Just went out and the fairys must have come last night and fixed it.Took it for a drive around the block and all was fine.Stopped and tried putting the heater on feet to see if it worked and the ICC flashed then all the aircon display disappeared and just the RECIRULATION symbol is flashing.Going to check connections again this morning.Hopefully its one of them. Link to comment Share on other sites More sharing options...
Maximus Member 1,627 Member For: 17y 10m 9d Gender: Male Location: Slip Sliding Away Posted 12/09/15 10:46 PM Author Share Posted 12/09/15 10:46 PM The Orange connector on the Passenger side wasn't clipped in all the way.Seems to have fixed the display on the ICC.Now its just the AIRBAG light that is on and wont go off.Ive checked the connectors under the seats and all the ones at the fuse box.Fuses are good too...........Im stumped! Link to comment Share on other sites More sharing options...
rokkie Member 87 Member For: 12y 4m Gender: Male Location: Adelaide, SA Posted 12/09/15 11:14 PM Share Posted 12/09/15 11:14 PM Could it be the connection under the icc on the tunnel? The one with the white pull tab. Center console has to come out to reach it Link to comment Share on other sites More sharing options...
barnz Member 3,047 Member For: 11y 2m Gender: Male Location: Brisbane Posted 13/09/15 01:28 AM Share Posted 13/09/15 01:28 AM Scan it, if you have U1900 something is unplugged Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 2m 24d Gender: Male Location: Perth Posted 13/09/15 03:04 AM Share Posted 13/09/15 03:04 AM It will be icc connectors. The plugs need to be installed in a certain order Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 3m 28d Gender: Male Location: Perth Posted 13/09/15 03:39 AM Share Posted 13/09/15 03:39 AM Did you disconnect the battery before disconnecting the harness plugs? Link to comment Share on other sites More sharing options...
