phoonf6 New Member 8 Member For: 11y 7m 19d Posted 07/09/15 06:49 AM Share Posted 07/09/15 06:49 AM Hey guys,Just recently bought a surge tank for my bf f6 and want to install and retune it on e85. Currently have 60lb injectors. What sort of power can they hold on e85?Other mods to the car are valve springs,cat, turbo side airbox, 255 in tank.Sent from my iPhone using Tapatalk Link to comment https://www.fordxr6turbo.com/forum/topic/91112-what-power-can-60lb-injectors-handle-on-e85/ Share on other sites More sharing options...
Skids4kids in the mid....not the bum like some Member 609 Member For: 12y 10d Gender: Male Posted 07/09/15 07:45 AM Share Posted 07/09/15 07:45 AM You would be looking at about 300-320rwkw depending on drivetrain. Link to comment https://www.fordxr6turbo.com/forum/topic/91112-what-power-can-60lb-injectors-handle-on-e85/#findComment-1560780 Share on other sites More sharing options...
phoonf6 New Member 8 Member For: 11y 7m 19d Posted 07/09/15 08:16 AM Author Share Posted 07/09/15 08:16 AM Zf autoSent from my iPhone using Tapatalk Link to comment https://www.fordxr6turbo.com/forum/topic/91112-what-power-can-60lb-injectors-handle-on-e85/#findComment-1560785 Share on other sites More sharing options...
Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 11y 8m 27d Gender: Male Location: Adelaide Posted 07/09/15 10:39 AM Share Posted 07/09/15 10:39 AM I run 360rw on 98 with deka 60's but I think that's at it limit. Dont fark around and just do it right and get ID1000'S or KPM one's. Link to comment https://www.fordxr6turbo.com/forum/topic/91112-what-power-can-60lb-injectors-handle-on-e85/#findComment-1560802 Share on other sites More sharing options...
bigpig New Member 3 Member For: 11y 8m 16d Posted 07/09/15 11:17 AM Share Posted 07/09/15 11:17 AM You should swap injectors if you want to run e85.. also eventually you will have to do parts of the fuel lines too... id1000 injectors will be what you want Link to comment https://www.fordxr6turbo.com/forum/topic/91112-what-power-can-60lb-injectors-handle-on-e85/#findComment-1560812 Share on other sites More sharing options...
BenDoCo I'm getten too old for this s**t Bronze Donating Members 4,509 Member For: 12y 26d Gender: Male Location: A big bridge over a river in South Australia Posted 07/09/15 12:18 PM Share Posted 07/09/15 12:18 PM Wouldn't a 255lph pump be a bit small for E85? Link to comment https://www.fordxr6turbo.com/forum/topic/91112-what-power-can-60lb-injectors-handle-on-e85/#findComment-1560818 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 5m 8d Gender: Male Location: Probably above atmospheric pressure Posted 07/09/15 12:22 PM Share Posted 07/09/15 12:22 PM Doesn't E85 use like 35% more flow to make the same power? But makes it cooler or whatever so you can get a higher final safe figure as long as the squirters and pumps are able to supply enough.So 60lb on E85 can make only a bit more than the 42lb I have in my car, which have been making 320 odd rwkw for five years and they are pretty maxed out. Link to comment https://www.fordxr6turbo.com/forum/topic/91112-what-power-can-60lb-injectors-handle-on-e85/#findComment-1560819 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 6m 6d Gender: Male Location: Perth Posted 07/09/15 01:16 PM Share Posted 07/09/15 01:16 PM They will be maxed quickly. Best change to new injectors to match to your goal power Link to comment https://www.fordxr6turbo.com/forum/topic/91112-what-power-can-60lb-injectors-handle-on-e85/#findComment-1560823 Share on other sites More sharing options...
Skids4kids in the mid....not the bum like some Member 609 Member For: 12y 10d Gender: Male Posted 07/09/15 10:03 PM Share Posted 07/09/15 10:03 PM Bizkets 60lb injectors on 98 will go well over 400rwkw easy.Base pressure plays a big role in capacity. Link to comment https://www.fordxr6turbo.com/forum/topic/91112-what-power-can-60lb-injectors-handle-on-e85/#findComment-1560836 Share on other sites More sharing options...
Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 11y 8m 27d Gender: Male Location: Adelaide Posted 07/09/15 10:03 PM Share Posted 07/09/15 10:03 PM My turbo wont though. Link to comment https://www.fordxr6turbo.com/forum/topic/91112-what-power-can-60lb-injectors-handle-on-e85/#findComment-1560837 Share on other sites More sharing options...
