Fg Mk2 G6E Turbo Fog Light Conversion
Fastaxi
  • New Member
  • Member For: 13y 3m 29d
Hi, just wondering if I can swap out the led driving light housing in the front off a mk2 g6e and swap to a g6 fog light housing so I can install some led halo fog lights from Mars performance? Also on any fg falcon that has fog lights how are they turned on/off, I know on my bf it was a switch but being a g6e turbo the front led driving lights are the parkers. Reason being is the lights I'm looking at activates the led halo once ignition is on but turn off when the parkers are switched on and then you must be able to turn the fog lights on with some sort off switch. Sorry if this sounds confusing but you may need to check out the led halo fog lights from mars to know what I'm on about.
Thanks for any input good or bad
