turbotrana Member 2,586 Member For: 22y 12d Gender: Male Posted 25/08/15 02:26 AM Share Posted 25/08/15 02:26 AM On 24/08/2015 at 11:51 AM, Bizkets is fat? said: Standard diff is the best. Plant it and spin into third in a straight line driving with your knees. Easy as. Haven't had a go in dons car yet with a true trac but if I did I would probably be drift king by the end off the night. I prefer a mechanical LSD cause of the predictability. As Bizkets said, no hands and it stays straight.Are the Eatons or these worm drives that unpredicatable. I have never tried one, if its harder to keep the worm drive LSDs straight or predictable then that is a bit of a worry.Maybe guys who have had both can chime in. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/91036-true-trac-or-kaaz-diff/page/3/#findComment-1559311 Share on other sites More sharing options...
Lennox Member 2,586 Member For: 12y 1m 16d Gender: Male Location: Perth Posted 25/08/15 02:53 AM Share Posted 25/08/15 02:53 AM Does your stock lsd literally stay straight? Mine quite often needs a bit of steering to get it straight.. does that mean it's not locking properly or something? Link to comment https://www.fordxr6turbo.com/forum/topic/91036-true-trac-or-kaaz-diff/page/3/#findComment-1559314 Share on other sites More sharing options...
XRSEXT Member 235 Member For: 12y 8m 15d Gender: Male Posted 25/08/15 03:27 AM Share Posted 25/08/15 03:27 AM (edited) hey mate, im running an eaton truetrac and its awesome. feels like a lot more power gets transferred to the wheels via the diff also, very quiet too Edited 25/08/15 03:27 AM by XRSEXT 1 Link to comment https://www.fordxr6turbo.com/forum/topic/91036-true-trac-or-kaaz-diff/page/3/#findComment-1559318 Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 22y 12d Gender: Male Posted 25/08/15 06:21 AM Share Posted 25/08/15 06:21 AM On 25/08/2015 at 2:53 AM, Lennox said: Does your stock lsd literally stay straight? Mine quite often needs a bit of steering to get it straight.. does that mean it's not locking properly or something?Its never straight straight, you always need steering input, more confident straight where it is not going to do something stupid Link to comment https://www.fordxr6turbo.com/forum/topic/91036-true-trac-or-kaaz-diff/page/3/#findComment-1559330 Share on other sites More sharing options...
barnz Member 3,047 Member For: 11y 4m 23d Gender: Male Location: Brisbane Posted 25/08/15 07:50 AM Share Posted 25/08/15 07:50 AM Far to many variables for any diff to stay dead straight when spinning. Predictability is the major difference between an LSD and a Locker which is pretty much what a trutrac is. Same wheel speed either side means its far more likely to do what you want it to do or act in a predictable way according to road surface, camber or tyre loading. Clutch type LSD's tend to have a mind f their own particularly when worn, when new and shimmed nice and tight they are OK.Sent from my GT-I9300 using Tapatalk 2 Link to comment https://www.fordxr6turbo.com/forum/topic/91036-true-trac-or-kaaz-diff/page/3/#findComment-1559335 Share on other sites More sharing options...
BenDoCo I'm getten too old for this s**t Bronze Donating Members 4,509 Member For: 12y 5d Gender: Male Location: A big bridge over a river in South Australia Posted 25/08/15 08:38 AM Share Posted 25/08/15 08:38 AM (edited) Why is mine so unfriggenpredictable then and what can I do about it?? I just swapped the oil out so I'll have a bit of a play in the next few days to see if new dyno juice makes a difference Edited 25/08/15 08:39 AM by BenDoCo Link to comment https://www.fordxr6turbo.com/forum/topic/91036-true-trac-or-kaaz-diff/page/3/#findComment-1559341 Share on other sites More sharing options...
demon1300 Member 435 Member For: 13y 2m 3d Gender: Male Posted 25/08/15 08:49 AM Share Posted 25/08/15 08:49 AM Wavetrac!/threadWith a true lifetime warranty and true torque biasing design, its won't just turn the wheel that lifts up like a trutrac. Far more predictable. Link to comment https://www.fordxr6turbo.com/forum/topic/91036-true-trac-or-kaaz-diff/page/3/#findComment-1559342 Share on other sites More sharing options...
stiv6 Member 42 Member For: 22y 3m 20d Gender: Male Posted 25/08/15 09:32 AM Share Posted 25/08/15 09:32 AM Is it possible to rebuild or tighten the factory LSD??If so where can I get a rebuild kit from?? 1 Link to comment https://www.fordxr6turbo.com/forum/topic/91036-true-trac-or-kaaz-diff/page/3/#findComment-1559349 Share on other sites More sharing options...
BenDoCo I'm getten too old for this s**t Bronze Donating Members 4,509 Member For: 12y 5d Gender: Male Location: A big bridge over a river in South Australia Posted 25/08/15 10:33 AM Share Posted 25/08/15 10:33 AM On 25/08/2015 at 8:49 AM, demon1300 said: Wavetrac!/threadWith a true lifetime warranty and true torque biasing design, its won't just turn the wheel that lifts up like a trutrac. Far more predictable.Do you have a Wavetrac installed demon? Link to comment https://www.fordxr6turbo.com/forum/topic/91036-true-trac-or-kaaz-diff/page/3/#findComment-1559357 Share on other sites More sharing options...
Silverfox666 Member 117 Member For: 10y 3m 16d Gender: Male Location: Sydney penrith Posted 25/08/15 10:37 AM Author Share Posted 25/08/15 10:37 AM Ok we went for a Harrop / Eaton true trac , apparently it's a bit stronger than a standard eaton true trac , it's ordered and should be at the workshop tomorrow with any luck , new gears and bearings to go with it Link to comment https://www.fordxr6turbo.com/forum/topic/91036-true-trac-or-kaaz-diff/page/3/#findComment-1559358 Share on other sites More sharing options...
