Help My Ford Falcon 2007 Bf Turbo Is Dying
cristopherdelima
  • Member For: 9y 4m
I recently bought a Falcon BF 2007 Turbo and realized that the Rear Diff is dead. If changing the gear from Park to Reverse or any gear except neutral it can create a continuous clunking sound and it is not running at all. Is there any chance to change the diff with different ratio because the ratio of the dead diff was 3.23 LSD.
Is there any difference between turbo diff to non-turbo diff?.
what is the better diff ratio for just daily driving?
Can I use any diffs from any ford falcon?.
Thank you in advance in helping a newbie.
post-85167-0-88999700-1440161326_thumb.j
  • 570Nm @1800rpm
  • Member For: 21y 2m 29d
When you say "not running at all", do you mean car is stationery?
If you have the car in gear with foot on brake the diff should not be making a continuous clunking sound.
Sounds more gearbox related to me, flex-plate possibly.
  • Member For: 9y 4m
But the rod connecting the gearbox to the diff is moving.
The clunking sound came from the rear it is like world war III is going inside the diff..
I would just like to know if its possible to change the diff ratio and change the whole diff? What are the best diff for this type of care?.
Please help me..
Sent from my iPhone using Tapatalk
  • Member For: 17y 7m 26d
My Car
BA MK2 Turbo, 2005, 6 speed manual.
I just checked the info stored in the PCM of my Car...
This is what I got re the Diff Ratio: http://s13.postimg.org/lt6kilit3/Diff_Ratio_2.jpg
You will have to replace your Diff with the same ratio of ( 3.23 )... Or you will / may get problems with your PCM getting wrong information from sensors... ABS and Speedo.
  • I'm getten too old for this s**t
  • Bronze Donating Members
  • Member For: 11y 8m 14d
With bloosted
