JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 17y 28d Gender: Male Location: Adelaide Posted 21/08/15 10:14 AM Share Posted 21/08/15 10:14 AM No you won't........Bwhahaha sorry had to #fandangle 2 Link to comment https://www.fordxr6turbo.com/forum/topic/91012-fg-heat-exchanger-genuine-vs-aftermarket-egpwr/page/5/#findComment-1558965 Share on other sites More sharing options...
Rab WOT? Moderating Team 10,981 Member For: 12y 4m 3d Gender: Male Location: Frankston, 3199 Posted 21/08/15 10:14 AM Share Posted 21/08/15 10:14 AM (edited) On 21/08/2015 at 9:53 AM, 454 said: Ok. Let me put it this way. I getting my zf built. What should I do Or - listen to what the guy building your ZF recommends Edited 21/08/15 10:15 AM by Rab Link to comment https://www.fordxr6turbo.com/forum/topic/91012-fg-heat-exchanger-genuine-vs-aftermarket-egpwr/page/5/#findComment-1558966 Share on other sites More sharing options...
Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 11y 10m 22d Gender: Male Location: Adelaide Posted 21/08/15 10:57 AM Share Posted 21/08/15 10:57 AM This is a sexy setup Link to comment https://www.fordxr6turbo.com/forum/topic/91012-fg-heat-exchanger-genuine-vs-aftermarket-egpwr/page/5/#findComment-1558983 Share on other sites More sharing options...
Tocchi Sandtrap Motorsport Donating Members 2,055 Member For: 16y 7m 3d Gender: Male Location: Perth Posted 21/08/15 01:49 PM Share Posted 21/08/15 01:49 PM On 21/08/2015 at 10:06 AM, Ralph Wiggum said: Study the information presented,do your research and make an informed decision. All you'll get from this thread is conflicting opinions.Go holinger to avoid any of these issues 2 Link to comment https://www.fordxr6turbo.com/forum/topic/91012-fg-heat-exchanger-genuine-vs-aftermarket-egpwr/page/5/#findComment-1558993 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 7m 4d Gender: Male Location: Probably above atmospheric pressure Posted 22/08/15 11:34 PM Share Posted 22/08/15 11:34 PM Don't build cars to avoid countless more issues hahaha Link to comment https://www.fordxr6turbo.com/forum/topic/91012-fg-heat-exchanger-genuine-vs-aftermarket-egpwr/page/5/#findComment-1559100 Share on other sites More sharing options...
GUN-808 Member 251 Member For: 11y 7m 18d Gender: Male Location: Gold Coast Posted 09/09/15 10:57 AM Share Posted 09/09/15 10:57 AM reviving this topic for some advice if anyone can help... ?Iv decided to go a different route.. still risking the milkshake but added bonus of actually cooling both oil/trans fluid when needed..Im going to replace the factory exchanger with an orange dot and continue to use this for the purposes of heating up etc so the zf wont freak out ..BUT also add this bloke to help cool temps of both trans fluid AND oil too at the same time.. (4 passes for the trans and 2 passes for oil)track days and a good booting on lap days will see both of these temps rise a lot and I cooked my oil last track day and lost a decent amount of oil pressure so I dont want to keep changing the oil as it broke down a fair bit..going to plumb it in under the passenger seat and tuck it up there.. My question is : what line would be better to plumb the cooler into from the heat exchanger ? to give the most accurate reading before or after the exchanger has done its job ?the front or the rear line and which is which ??hopefully this gets me a good cooling system when im into it .. will be set up with a Davies Craig digital thermo controller and set to about 93-95 degrees on the trans side and it will cool the oil too when the trans temp rises.. total cost about $700 all installed with new orange dot item too.. Link to comment https://www.fordxr6turbo.com/forum/topic/91012-fg-heat-exchanger-genuine-vs-aftermarket-egpwr/page/5/#findComment-1561050 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 8m 1d Gender: Male Location: Perth Posted 09/09/15 01:45 PM Share Posted 09/09/15 01:45 PM Drop the fan temp down to 80-85c. Run the oil first through the factory heat exchanger and then the cooler. Link to comment https://www.fordxr6turbo.com/forum/topic/91012-fg-heat-exchanger-genuine-vs-aftermarket-egpwr/page/5/#findComment-1561069 Share on other sites More sharing options...
GUN-808 Member 251 Member For: 11y 7m 18d Gender: Male Location: Gold Coast Posted 10/09/15 01:28 AM Share Posted 10/09/15 01:28 AM Cool that's what I was thinking too..But which line is which ?? Plumb into front or rear line on the exchanger ??And temps that low ?? I really didn't want the fan to work unless in a situation where it's getting too hot.. The flow underneath the car should give it enough cooling without needing to use the fan all the time yeah ?? I thought the trannys liked to work on 90deg.. Link to comment https://www.fordxr6turbo.com/forum/topic/91012-fg-heat-exchanger-genuine-vs-aftermarket-egpwr/page/5/#findComment-1561128 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 8m 1d Gender: Male Location: Perth Posted 10/09/15 06:37 AM Share Posted 10/09/15 06:37 AM Bottom fitting on the gearbox is the outlet. Take the oil through the heat exchanger first then through the air oil cooler. This is the same way ford do it. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/91012-fg-heat-exchanger-genuine-vs-aftermarket-egpwr/page/5/#findComment-1561164 Share on other sites More sharing options...
