  • ...JD TUNING ADELAIDE...
  • Member For: 16y 11m 20d
  On 11/08/2019 at 3:48 AM, gaz097 said:
Comes on at 20, tapers to 24 in the top end.
The only one I know off that can do that is the eboost 2, as can demand duty cycle per rpm.
I assume the factory can as well?
Expand
Yes the factory ecu can request different boost from the start of a sweep to the limiter
Aftermarket EBC’s actually don’t work correctly unless connected to a tach driver
Arron is being a flog again because he can’t comprehend a G2 GTX 82 is a 66mm turbo with a 0.7 comp cover despite the fact anyone would assume by now he could actually understand and recognise what is available for the XR6T platform and thus realise his one off fully custom built Nizpoo unicorn is unlike any other turbo falcon and can never be compared in a fair way ....... jusss saynnnnnn
Still irrelevant to what Gaz asked
you never have any idea, what’s new 🤔
  • Like 2
  • Member For: 20y 4m 17d
  On 11/08/2019 at 4:02 AM, arronm said:
yeh,  my boost is in at 2800rpm. Why is yours so LAZY....
Because apparently the best tuner in the west only knows how to set 100% WG duty cycle and cant tune closed loop.
Using exhaust restrictions and fuel system limits doesnt constitute boost control.
  • Haha 1
I’ve never ever seen a better time to apply Aloe vera ......
  • Like 2
  • Member For: 10y 11m 13d
Expand
Of course it can. Factory boost control sh*ts all over anything aftermarket in so many ways it isn't funny. I have no idea why people continue to spend money to go backwards, well actually I do but it doesn't stop it being frustrating.
Factory has a 2D table of duty cycle vs rpm vs intake temp.
Boost by gear.
Underboost threshold eg 100% duty before you've reached your commanded boost pressure which means it will spool faster.
Overboost threshold to protect against overboost.
Proper PID closed loop boost control which means you can hit the same boost pressure in 0c or 45c ambient no problem.
The factory PCM even models how the heat soak causes the actuator rod to expand and change the preload, it then accounts for this.
Eboost is a dinosaur compared to it.
Expand
Well in fairness running an inlet bypass to control boost it does produce a good result with almost zero effort if its a race car.
  • Bronze Donating Members
  • Member For: 13y 10m
Boost by gear.
Boost per gear even in a manual??
I've seen the fancy launch control boost thing when the clutch switch was activated, Mick posted the other day.
Yes it is not the 1990s. The PCM can accurately determine which gear is active based on the output shaft speed, clutch position, known gear ratios and vehicle speed. Even the BA has all the information required to do it, it just isn't set up.
Edited by rollex
