IH8TOADS Silver Donating Members 3,618 Member For: 19y 10m 2d Gender: Male Location: OZ Posted 13/08/12 02:42 AM Share Posted 13/08/12 02:42 AM Yes any DMR can't be logged. Basically all useful tune info is not retrievable if using an xcal3 to log a BA. Link to comment https://www.fordxr6turbo.com/forum/topic/91004-diy-tuning/page/8/#findComment-1278597 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 17d Gender: Male Location: Perth Posted 13/08/12 03:24 AM Author Share Posted 13/08/12 03:24 AM to those that asked for them, I have email some stock tunes out. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/91004-diy-tuning/page/8/#findComment-1278613 Share on other sites More sharing options...
Mr_4.0 Member 1,096 Member For: 14y 3m 21d Posted 13/08/12 03:54 AM Share Posted 13/08/12 03:54 AM I no longer have an sct tune in my car. Tune is just loaded into my PCM. Been thinking about doing a trade with someone with an xcal 2 so I can datalog properly. At the moment my xcal3 basically just gets used to read codes haha. Link to comment https://www.fordxr6turbo.com/forum/topic/91004-diy-tuning/page/8/#findComment-1278637 Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 5m 18d Gender: Male Location: SE Melbourne Posted 13/08/12 03:59 AM Share Posted 13/08/12 03:59 AM I have a BF1 with xcal2. Would I have the same problem not being about to read DMR with xcal3? Link to comment https://www.fordxr6turbo.com/forum/topic/91004-diy-tuning/page/8/#findComment-1278639 Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 22y 1m 10d Gender: Male Posted 13/08/12 04:45 AM Share Posted 13/08/12 04:45 AM (edited) This is the calibration sheet that relates to the injectors I want to use. These are easy to convert to metric and I guess this table helps heaps. These injectors flow aroud 60lb at 4bar and one of the few you can get calibration sheets for bar the ID ones (I think)Fuel injection adjustmentSpeed density tables.So its quite easy extracting the info from the calibration sheet to put in the Fuel/injector page.So I gotta put inFlow rate highFlow rate lowflow rate high vs pressureflow rate low vs pressurebreakpointoffset vs voltageoffset vs pressure (I think they are zeroed out on this ford tune)min pulse width.Now how close to the tune will this get me?So for the fine tune I got to go to the Speed density tables.Which table do I adjust hereThe spark and wastegate part of it looks not too bad to sort out Edited 13/08/12 04:49 AM by turbotrana Link to comment https://www.fordxr6turbo.com/forum/topic/91004-diy-tuning/page/8/#findComment-1278656 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 17d Gender: Male Location: Perth Posted 13/08/12 05:00 AM Author Share Posted 13/08/12 05:00 AM Very Few people adjust the SD tables, most adjust injector slopes to achieve Commanded AFR's with minimal fuel trims.Adjust hi/lo slop start around 80lo and 73hi Adjust Lo until Open Loop Afrs @ idle matches Commanded and Same for Hi until Hi matches open loop commanded at WOTLeave flow rate V pressure stock as our cars don't reference this. (those values are used in returnless systems)Break point or around .0000385lbSet you battery offset table so the value @ 14v + the Min Pw is apros 1.5ms. Then adjust the offset in small increments (like 5%) until your CL Idel LTFT are within around 5% +/-that's a starting point. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/91004-diy-tuning/page/8/#findComment-1278667 Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 22y 1m 10d Gender: Male Posted 13/08/12 06:30 AM Share Posted 13/08/12 06:30 AM Those figures you supply are very different to what I would have extrapolated from the calibration table.So if I look at the calibration table I provided abovethe low injector slope is .015913lb/sec = 7.2g/secthe high injector slope is 0.013497lb/sec = 6.122 g/secbut then this was at 39.15psi.Factor into 58psi (4bar) and you have to uplift the above by the square root of 58/39.15 = 1.217So I would have thought the starting point as per these calibration tables would below slope 7.2 X 1.217 = 8.764high slope 6.122 X 1.217 = 7.45Even the injector offset is way different.So I would have original thought the calibration table was a good place to start but seems not Link to comment https://www.fordxr6turbo.com/forum/topic/91004-diy-tuning/page/8/#findComment-1278699 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 17d Gender: Male Location: Perth Posted 13/08/12 06:35 AM Author Share Posted 13/08/12 06:35 AM On 13/08/2012 at 6:30 AM, turbotrana said: So I would have original thought the calibration table was a good place to start but seems notWelcome to tuning Aus Ford with SD calibrations. When you get your software in, bang in the corrected 4bar figures and see what the trims and AFR's are like, They try again with the figures I've posted. they wont be bang on but I can just about guarantee they will be better than any like for like injector calibration data. Link to comment https://www.fordxr6turbo.com/forum/topic/91004-diy-tuning/page/8/#findComment-1278701 Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 22y 1m 10d Gender: Male Posted 13/08/12 06:41 AM Share Posted 13/08/12 06:41 AM (edited) Fuel breakpoint according to the calibration table is 0.0000144400lb or .0000065498738228kg at 39.15psiuplift it by 1.2173195 to equate 58psi would make Fuel breakpoint for these injectors at .00000797328kgThe ford factory figure in the above table is 0.000009975kgThis is very different to your 0.0000385lbI dont have a clue how these affect the fueling but will find out once I get my VCM pro deliveredI will let this be until I have an actual play with it. Thanks just read your above post. Edited 13/08/12 06:45 AM by turbotrana Link to comment https://www.fordxr6turbo.com/forum/topic/91004-diy-tuning/page/8/#findComment-1278703 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 17d Gender: Male Location: Perth Posted 13/08/12 06:45 AM Author Share Posted 13/08/12 06:45 AM set it to .000009975kg's and it will idle beautifully as it will be pig rich. That figure will have engine idling on the injectors hi slope values and it will be BS rich. Link to comment https://www.fordxr6turbo.com/forum/topic/91004-diy-tuning/page/8/#findComment-1278704 Share on other sites More sharing options...
