turbotrana Member 2,586 Member For: 22y 1m 15d Gender: Male Posted 06/10/15 11:41 PM Share Posted 06/10/15 11:41 PM Setting the O2 temp to 2500 deg does not work (not in my strategy). Surprised it set trims to 0. It may work on your strategy.Normally you just set the throttle position/closed loop table to a high double digit number in all boxes and that is it.You cant stop closed loop at idle. It wont let you do it. But the setting of the 02 to 2500 is meant to work on the mustangs and mentioned in the La Sota online tuning manual but not our Fords from when I tried it. Link to comment https://www.fordxr6turbo.com/forum/topic/91004-diy-tuning/page/26/#findComment-1564331 Share on other sites More sharing options...
DarrylC Member 51 Member For: 12y 4m 2d Posted 07/10/15 12:02 AM Share Posted 07/10/15 12:02 AM Agree with turbotrana. I have had success with the delay. Increased it to 5 minutes to get my readings once. Think the max value HPT is 65000 seconds which is over 18 hours Link to comment https://www.fordxr6turbo.com/forum/topic/91004-diy-tuning/page/26/#findComment-1564332 Share on other sites More sharing options...
rollex Member 683 Member For: 10y 11m 7d Gender: Male Location: Australia Posted 07/10/15 01:14 AM Share Posted 07/10/15 01:14 AM I got that tip from the La Sota manual however I believe it worked as my fuel trims were locked at 1.00, eg the same as on cold start when it is in open loop. I will try changing the delay instead but I suspect it is already in open loop.What happens if I unplug the O2 sensor, will it throw a fault code and go into open cloop? Or will it also do a bunch of other things?Anyway commanded lambda, are there any other catchas that could cause it to show 1.00 when it isn't really?I also did some data logging on my SCT tune for lols and found that my STFT are swinging as far as 0.8 and 1.15 at times. What kind of trims are considered acceptable, a few % max? Link to comment https://www.fordxr6turbo.com/forum/topic/91004-diy-tuning/page/26/#findComment-1564338 Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 22y 1m 15d Gender: Male Posted 07/10/15 05:12 AM Share Posted 07/10/15 05:12 AM Just checked my tune.I meant to say "open loop fuel TPS threshold" set to zero. Link to comment https://www.fordxr6turbo.com/forum/topic/91004-diy-tuning/page/26/#findComment-1564364 Share on other sites More sharing options...
hobo Member 22 Member For: 17y 6m 24d Gender: Male Location: NSW Posted 14/10/15 09:17 PM Share Posted 14/10/15 09:17 PM Finally got my car onto a dyno to see how much power its making. Has only been tuned on the road by me. I wish he had stuck his wideband in it for a log but it was just a rush job cause he was busy. Hopefully I can crack 400 Diy road tuned 3 Link to comment https://www.fordxr6turbo.com/forum/topic/91004-diy-tuning/page/26/#findComment-1565010 Share on other sites More sharing options...
Peppy_t92 Silver Donating Members 748 Member For: 12y 1m 12d Gender: Male Location: Liverpool Posted 14/10/15 09:26 PM Share Posted 14/10/15 09:26 PM Good stuff hobo!.. 98 or e85? AFR's would of been handy, how do you log them when street tuning? Link to comment https://www.fordxr6turbo.com/forum/topic/91004-diy-tuning/page/26/#findComment-1565012 Share on other sites More sharing options...
hobo Member 22 Member For: 17y 6m 24d Gender: Male Location: NSW Posted 14/10/15 09:45 PM Share Posted 14/10/15 09:45 PM Thanks. Only 98 at this stage. I have an mtx-l in the dash pod that I connect to the mpvi Link to comment https://www.fordxr6turbo.com/forum/topic/91004-diy-tuning/page/26/#findComment-1565015 Share on other sites More sharing options...
barnz Member 3,047 Member For: 11y 5m 25d Gender: Male Location: Brisbane Posted 14/10/15 09:56 PM Share Posted 14/10/15 09:56 PM Pretty tidy looking curve there mate. Nice 2 Link to comment https://www.fordxr6turbo.com/forum/topic/91004-diy-tuning/page/26/#findComment-1565016 Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 9m 24d Posted 15/10/15 08:51 AM Share Posted 15/10/15 08:51 AM Is there a way to eliminate very low rpm knock? If so you could make millions tuning Toyota's here in Bali. I think the fuel here is around 75 octane lol Sent from my HTC_0PJA10 using Tapatalk Link to comment https://www.fordxr6turbo.com/forum/topic/91004-diy-tuning/page/26/#findComment-1565085 Share on other sites More sharing options...
rollex Member 683 Member For: 10y 11m 7d Gender: Male Location: Australia Posted 15/10/15 11:00 AM Share Posted 15/10/15 11:00 AM It is called toluene Link to comment https://www.fordxr6turbo.com/forum/topic/91004-diy-tuning/page/26/#findComment-1565095 Share on other sites More sharing options...
