  • Member For: 10y 10m 5d
  On 05/10/2015 at 5:52 AM, Peppy_t92 said:
I don't use livelink, but if you have set your base table to 0.85 then it's mega lean.. Drop your Low slope to like 110 and put your base fuel table back to standard but change the values in the bottom right to 0.8-0.82 or so
I put the entire base table to 0.85 to just confirm the commanded AFR is going to match and just drove it with very light throttle. I'm not actually going to leave it like that I just want to get the AFR to match.
What I want to know is why am I reading 16:1 with a commanded lambda of 0.85 with O2 feedback disabled. If the injector data is correct what else needs touching for it to match?
  • Member For: 12y 10d
This is where the altering of the slopes comes into play, it's manipulating the SD calculations to achieve your targets
I see so the SD maps do need to be tweaked, I thought unless you made substantial modifications they were ok but it appears I misread.
I'd rather alter the SD maps then just tweak injector slopes.
  • Member For: 22y 14d
Lower the slopes to make it richer
http://www.hptuners.com/forum/showthread.php?50588-ID-1000-injector-data-rough-idle-when-cold
These are the values used by a "pro" tuner on an FG. I don't like his injector offsets and the car used to run rough at startup indicating to me that the high slope may be a bit lean IMO. (BTW have not used ID1000) but we will get yours running fine.
Nevertheless lower the slopes by 5 to 10 lb and leave the rest the same. Its all about the slopes now. Forget SD. Go for a drive. If at cruise lean compared to desired lambda then lower the hi slope.
If at idle lean then lower the lo slope. Just chuck them both at 110 and see where you are.
Edited by turbotrana
Ok I'm sure it will be easy to get mixtures correct just by changing them. Don't think I'll have time to play again for at least 2 weeks though.
Jetturbo do you time via slopes these days?
Cheers
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 10m 13d
I've never raced an asian before
On my bucket list though
  • Like 3
