Impellor Member 835 Member For: 14y 9m 16d Gender: Not Telling Posted 06/08/12 10:56 AM Share Posted 06/08/12 10:56 AM Im personally interested in tuning, but it is difficult to get info. I actually think that there is an opportunity to have an all vehicle Australian based forum, as the necessary tools for in car tuning are well within reach from a cost perspective. Great thread Ralphie. Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/91004-diy-tuning/page/2/#findComment-1275579 Share on other sites More sharing options...
JVK Silver Donating Members 751 Member For: 19y 4m 18d Gender: Male Location: North West Hot Hell,VIC Posted 06/08/12 11:23 AM Share Posted 06/08/12 11:23 AM On 06/08/2012 at 10:44 AM, turbotrana said: I am surprised that no one has done a tuning guide for VCM suite. I have seen guides for GM vehicles but no one so far has done a step by step guide for the tables to look at and adjust in VCM.The best place to put a wideband is on the turbo dump. Best just to weld in an extra bung. Using the tailpipe is not the best way as it does take time for the exhaust to get to the rear and it does not give a good reading at idle. If you datalog the data does not closely match RPM/Load when it is in the tailpipe. Tuners who use still use the tailpipe should be shot.Innovate have good wideband sensors and logging software.If you are a novice just forget the timing advance maps. If using stock maps any knock detection is not needed.You might need a SCT handheld tuner to datalog the Wideband along side RPM and MAP. It will give the best chance of knowing where you are in the tune. But I reckon you could get an inovate to get valid datalogging data also.I want to get rid of the Nizpro injectors in my car which was tuned with a SCT so I need to start getting familiar with the VCM software. I have alot of tuning experience so I can help there (that's easy) but I need help with the VCM software.What injectors were you thinking of using? Link to comment https://www.fordxr6turbo.com/forum/topic/91004-diy-tuning/page/2/#findComment-1275590 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 13d Gender: Male Location: Perth Posted 06/08/12 12:29 PM Author Share Posted 06/08/12 12:29 PM On 06/08/2012 at 10:44 AM, turbotrana said: I am surprised that no one has done a tuning guide for VCM suite. I have seen guides for GM vehicles but no one so far has done a step by step guide for the tables to look at and adjust in VCM.The best place to put a wideband is on the turbo dump. Best just to weld in an extra bung. Using the tailpipe is not the best way as it does take time for the exhaust to get to the rear and it does not give a good reading at idle. If you datalog the data does not closely match RPM/Load when it is in the tailpipe. Tuners who use still use the tailpipe should be shot.Innovate have good wideband sensors and logging software.If you are a novice just forget the timing advance maps. If using stock maps any knock detection is not needed.You might need a SCT handheld tuner to datalog the Wideband along side RPM and MAP. It will give the best chance of knowing where you are in the tune. But I reckon you could get an inovate to get valid datalogging data also.I want to get rid of the Nizpro injectors in my car which was tuned with a SCT so I need to start getting familiar with the VCM software. I have alot of tuning experience so I can help there (that's easy) but I need help with the VCM software.Demo:http://www.hptuners.com/index.phpAlso I wouldn't be relying on fords timing table if you plan to increase boost above standard. Especially in a b series Link to comment https://www.fordxr6turbo.com/forum/topic/91004-diy-tuning/page/2/#findComment-1275628 Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 22y 1m 6d Gender: Male Posted 06/08/12 03:17 PM Share Posted 06/08/12 03:17 PM (edited) I have some Ford Racing/Bosch G302/0280158117 EV14s. They are a 8 hole injector and will flow 60lb (635cc) at 4 bar. There is a calibration table that comes with this particular injector that should assist tuning.I bought my FG modified (something I swear I would never do as I have always modified my own cars) but it was done professionally by a workshop with all good bits for free basically but I just dont like the Nizpro drilled injectors. THey have sh*tty behaviours which the G302s should rectify and still give me the 365kw it has now.Thanks for the Demo link also. Edited 06/08/12 03:20 PM by turbotrana Link to comment https://www.fordxr6turbo.com/forum/topic/91004-diy-tuning/page/2/#findComment-1275648 Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 9m 28d Gender: Male Location: OZ Posted 06/08/12 10:42 PM Share Posted 06/08/12 10:42 PM I ran 4.5 bar with those injectors when I tested them at roughly that power, but my mixtures are fairly fat. What is your actual lambda and boost at the redline, I'll tell you roughly what duty cycle you will be at. If you need a bit more flow and have spare pump capacity you can have this reg, it's a drop in replacement and is blueprinted to 4.5. Tuning wise you just need to adjust all injector scaling tables to suit. Very basic task. In regards to the Nizpro squirters, have a look at the calibration and I bet your injector offset table is factory, you breakpoint is quite low (under 0.000017 lb per stroke) and your injector slopes are on the pi$$. I.e the high slope is higher than the low slope. I'm not at all a fan of drilled injectors but I found the nizpro items to work ok, apart from them being thirsty, obviously atomize poorly. Link to comment https://www.fordxr6turbo.com/forum/topic/91004-diy-tuning/page/2/#findComment-1275675 Share on other sites More sharing options...
freeze_dk I am dissatisfied with my current employment situation Donating Members 8,610 Member For: 18y 7m 8d Gender: Male Posted 07/08/12 01:18 AM Share Posted 07/08/12 01:18 AM Ill love to know how to tune but I dont understand anything in here 1 Link to comment https://www.fordxr6turbo.com/forum/topic/91004-diy-tuning/page/2/#findComment-1275724 Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 5m 14d Gender: Male Location: SE Melbourne Posted 07/08/12 01:54 AM Share Posted 07/08/12 01:54 AM (edited) Quote Where Standard vs. Pro differ is the Pro version offers stand-alone data logging that allows you to scan the car without hauling a computer along with you. The Pro version also accepts 0-5V inputs so that you can log air fuel ratio (or other information) along with your OBD2 parameters. With that said, I would seriously consider the MPVI Pro if you have (or are planning) any sort of modifications to the vehicle(s) you will be tuning as this will allow you to data log your Air Fuel Ratio etc. and display it right along with the parameters logged with HP Tuners Scanner. This eliminates the need to analyze data from a separate software system, or worse yet, write down the AFR at certain RPM and load points. Otherwise, if you will not be modifying the vehicle, the Standard will be more than sufficient.Does that mean I can get the pro version and connect and wideband o2 sensor directly without the need of another logger? That would be neat. Edited 07/08/12 01:54 AM by Paulie2256 Link to comment https://www.fordxr6turbo.com/forum/topic/91004-diy-tuning/page/2/#findComment-1275735 Share on other sites More sharing options...
Impellor Member 835 Member For: 14y 9m 16d Gender: Not Telling Posted 07/08/12 02:02 AM Share Posted 07/08/12 02:02 AM On 07/08/2012 at 1:54 AM, Paulie2256 said: Does that mean I can get the pro version and connect and wideband o2 sensor directly without the need of another logger? That would be neat.Certainly appears to be the case Paulie. Cheap as chips too. Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/91004-diy-tuning/page/2/#findComment-1275740 Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 9m 28d Gender: Male Location: OZ Posted 07/08/12 02:10 AM Share Posted 07/08/12 02:10 AM Might as well get an LM-2. Does the same thing but much easier to use and a neater mobile unit. You can also wire it into the xcal. My LM-2 analog cable has outputs for the xcal2 (mini din), xcal3 (FireWire) and a generic for aftermarket ECU's that I tinker with. As long as the ground offsets are configured correctly its a weapon combo. Link to comment https://www.fordxr6turbo.com/forum/topic/91004-diy-tuning/page/2/#findComment-1275742 Share on other sites More sharing options...
Impellor Member 835 Member For: 14y 9m 16d Gender: Not Telling Posted 07/08/12 02:14 AM Share Posted 07/08/12 02:14 AM Here is the Xcal 2 manual. For the LM-2.CheersXCal2Manual.pdf Link to comment https://www.fordxr6turbo.com/forum/topic/91004-diy-tuning/page/2/#findComment-1275746 Share on other sites More sharing options...
