gaz097 Bronze Donating Members 1,752 Member For: 13y 9m 21d Posted 28/08/15 03:51 PM Share Posted 28/08/15 03:51 PM Can you find it before turbo? Link to comment https://www.fordxr6turbo.com/forum/topic/91004-diy-tuning/page/19/#findComment-1559752 Share on other sites More sharing options...
rollex Member 683 Member For: 10y 11m 4d Gender: Male Location: Australia Posted 28/08/15 11:32 PM Share Posted 28/08/15 11:32 PM There are too many sensors I know what is what. I'll try and find a workshop manual. Link to comment https://www.fordxr6turbo.com/forum/topic/91004-diy-tuning/page/19/#findComment-1559759 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,493 Member For: 17y 1m 2d Gender: Male Location: Melbourne Posted 29/08/15 12:00 AM Share Posted 29/08/15 12:00 AM On 26/08/2015 at 7:41 AM, IH8TOADS said: Air temp is measured by the t-MAP....so in the manifold. Link to comment https://www.fordxr6turbo.com/forum/topic/91004-diy-tuning/page/19/#findComment-1559762 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 19d Gender: Male Location: Perth Posted 29/08/15 12:00 AM Author Share Posted 29/08/15 12:00 AM Iat is internal in the tmap. Tmap = temperature and absolute pressure for the manifold Link to comment https://www.fordxr6turbo.com/forum/topic/91004-diy-tuning/page/19/#findComment-1559763 Share on other sites More sharing options...
rollex Member 683 Member For: 10y 11m 4d Gender: Male Location: Australia Posted 29/08/15 12:28 AM Share Posted 29/08/15 12:28 AM Ok cool, it seems intercoolers work much better than I thought. I had no idea. Link to comment https://www.fordxr6turbo.com/forum/topic/91004-diy-tuning/page/19/#findComment-1559765 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 11m 11d Gender: Male Location: Adelaide Posted 29/08/15 01:29 AM Share Posted 29/08/15 01:29 AM 2 Link to comment https://www.fordxr6turbo.com/forum/topic/91004-diy-tuning/page/19/#findComment-1559768 Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 22y 1m 12d Gender: Male Posted 29/08/15 02:10 AM Share Posted 29/08/15 02:10 AM (edited) The turbo will put out hotter air when it is worked regardless.However the sensor will get a bit heat soaked when you are cruising around.Start pushing more air thru and it cools the sensor down a bit.Location of sensors is very important. I don't like the IAT sensor being positioned in the engine bay. It should be located on the outlet of the intercooler to get a more accurate reading.Also the air getting thrashed around a bit more in the intercooler may be another factor.It is a good observation. Maybe you can change the position of the sensor down the track. Don't know how it will affect the map part. But for now don't worry about it too much.When I did programable engine management systems I would put the iat temp sensor out of the way of any heat. Otherwise it would muck up fuel temp compensations, it really would not reflect what was going on if located in a position of where heat would radiate onto it. Edited 29/08/15 02:17 AM by turbotrana Link to comment https://www.fordxr6turbo.com/forum/topic/91004-diy-tuning/page/19/#findComment-1559771 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 11m 15d Gender: Male Location: @ my laptop Posted 29/08/15 03:17 AM Share Posted 29/08/15 03:17 AM the location of the sensor on the Barra is pretty much perfect 3 Link to comment https://www.fordxr6turbo.com/forum/topic/91004-diy-tuning/page/19/#findComment-1559777 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,493 Member For: 17y 1m 2d Gender: Male Location: Melbourne Posted 29/08/15 03:30 AM Share Posted 29/08/15 03:30 AM Agreed. As close to the actual intake port as possible is ideal. Link to comment https://www.fordxr6turbo.com/forum/topic/91004-diy-tuning/page/19/#findComment-1559780 Share on other sites More sharing options...
rollex Member 683 Member For: 10y 11m 4d Gender: Male Location: Australia Posted 29/08/15 04:15 AM Share Posted 29/08/15 04:15 AM Yeah it might get heat soaked but I guess the air is a similar temp and taking up that heat so it is accurate. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/91004-diy-tuning/page/19/#findComment-1559781 Share on other sites More sharing options...
