rollex Member 683 Member For: 10y 11m 2d Gender: Male Location: Australia Posted 19/08/15 12:11 AM Share Posted 19/08/15 12:11 AM Yeah I'm going to spend the weekend reading all of the guides to get an understanding then start doing some datalogging to confirm what my car is doing with the current tune. I still need to purchase a wideband so be a few weeks away before I start playing. Link to comment https://www.fordxr6turbo.com/forum/topic/91004-diy-tuning/page/15/#findComment-1558626 Share on other sites More sharing options...
camo86T Silver Donating Members 1,810 Member For: 11y 2m 28d Gender: Male Location: SW Sydney Posted 20/08/15 06:49 AM Share Posted 20/08/15 06:49 AM For me, reading these tuning threads is sort of like being tied up and thrown into a tank full of 18yo single malt#wayovermyheadanddrowningbutreallyenjoying it Link to comment https://www.fordxr6turbo.com/forum/topic/91004-diy-tuning/page/15/#findComment-1558854 Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 9m 20d Posted 20/08/15 10:57 AM Share Posted 20/08/15 10:57 AM Camo read a few of the common threads once a week. Sinks in pretty quick. I'm yet to take the plunge but I'm confident I can tune my car pretty quick, and it will be tuned towards 450rwkw on e85 which will add a few extra layers. Link to comment https://www.fordxr6turbo.com/forum/topic/91004-diy-tuning/page/15/#findComment-1558869 Share on other sites More sharing options...
Peppy_t92 Silver Donating Members 748 Member For: 12y 1m 8d Gender: Male Location: Liverpool Posted 20/08/15 08:10 PM Share Posted 20/08/15 08:10 PM (edited) The HP forum is good for info on using the software, but you should also understand the how's, whys, what's, of tuning and combustion engines, there's plenty of books that give you a guide This was a great readonce you start logging your own car and matching maps to logged data you learn pretty quickly what does what and by how much Edited 20/08/15 08:23 PM by Peppy_t92 1 Link to comment https://www.fordxr6turbo.com/forum/topic/91004-diy-tuning/page/15/#findComment-1558885 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 17d Gender: Male Location: Perth Posted 20/08/15 11:18 PM Author Share Posted 20/08/15 11:18 PM All of Greg's books are excellent. Unfortunatly nothing has been specifically written for Aus Ford but as Pep started if you understand the basics you can build on that.It's not Rocket Surgery, It's all about inputs and outputs from the PCM. Link to comment https://www.fordxr6turbo.com/forum/topic/91004-diy-tuning/page/15/#findComment-1558898 Share on other sites More sharing options...
rollex Member 683 Member For: 10y 11m 2d Gender: Male Location: Australia Posted 24/08/15 10:28 AM Share Posted 24/08/15 10:28 AM (edited) I posted this on HPT but wondering if anyone has different answers here:Ok so I've been reading the lasota racing manual and msot of it is stuff I already understand but it is definitely a good read. The following questions are mainly about speed density as that is the thing that is doing my head in. To try and understand things better I've assumed two things in this scenario, wide open throttle (TPS of 50%) and no variable cam timing, eg it is locked and no other correction maps in play, eg ignoring temp etc. This means the simplified equation is:fuel_injected = commanded lambda (fuel base vs rpm vs tps) * MAP at x cam degrees at y rpm * actual air pressure in inlet This means the PCM will figure out the fuel to inject based on the air pressure * volumetric efficiency in the MAP per airmass high res table * commanded AFR Now this brings a few questions up. What if I want to run 11:1 AFR at WOT with 18psi but I want to run 12:1 AFR at WOT with 12 psi? The main fuel base map is rpm vs TPS? Why is it not rpm vs load eg like the spark maps? Now I'm sure I could get the result I'm after by tweaking the injector slopes or a bunch of other methods but that means making a hack tune which isn't what I want to do. The next question is what about the cam position, how is this commanded? I'm guessing the reason the cam angle vs rpm table exists is because the different cam angles change volumetric efficiency? eg the amount of fuel required to obtain a given AFR at a given psi changes Also can anyone answer this question about map resolution?http://www.hptuners.com/forum/showthread.php?53120-help-rolls-transition-from-a-tuna-to-a-tuner&p=395279&viewfull=1#post395279 Edited 24/08/15 10:35 AM by rollex Link to comment https://www.fordxr6turbo.com/forum/topic/91004-diy-tuning/page/15/#findComment-1559241 Share on other sites More sharing options...
eff xr6t Member 569 Member For: 11y 7m 10d Posted 24/08/15 10:33 AM Share Posted 24/08/15 10:33 AM Why do you want to make it richer with more boost? Link to comment https://www.fordxr6turbo.com/forum/topic/91004-diy-tuning/page/15/#findComment-1559244 Share on other sites More sharing options...
rollex Member 683 Member For: 10y 11m 2d Gender: Male Location: Australia Posted 24/08/15 10:49 AM Share Posted 24/08/15 10:49 AM Well if I'm running low boost then I can probably get away with 12 or 12.5 AFR without detonating, eg half throttle on a straight line or 1/4 throttle up a hill.If I'm WOT then I will need closer to 11-11.5:1 with 16+ psi.The issue is load isn't proportional to your foot position, you can get close to full load with half throttle going up a hill. Going down a hill at a lower speed you won't get f*ck all load with half throttle.The reason I asked is I normally tune load vs rpm. Eg very easy to simply add more fuel at peak torque at full load, doesn't matter if I'm 25% or 100% throttle, if there is that much airflow it will be that rich. There is a good reason why the ignition tables are load vs rpm, because going up a hill vs going down a hill at the same boost and throttle position will accept differing amounts of spark before detonating, I just don't get why AFR is programmed differently in these cars. Link to comment https://www.fordxr6turbo.com/forum/topic/91004-diy-tuning/page/15/#findComment-1559246 Share on other sites More sharing options...
rollex Member 683 Member For: 10y 11m 2d Gender: Male Location: Australia Posted 24/08/15 10:50 AM Share Posted 24/08/15 10:50 AM Another question is how good is the knock detection in these cars, can I simply log knock and it will let me know if there is mild detonation? Or do I require knock ears? Link to comment https://www.fordxr6turbo.com/forum/topic/91004-diy-tuning/page/15/#findComment-1559247 Share on other sites More sharing options...
rollex Member 683 Member For: 10y 11m 2d Gender: Male Location: Australia Posted 25/08/15 06:48 AM Share Posted 25/08/15 06:48 AM Anyone ? Link to comment https://www.fordxr6turbo.com/forum/topic/91004-diy-tuning/page/15/#findComment-1559331 Share on other sites More sharing options...
