Fg F6 Low Dyno Numbers
mooks
  • New Member
  • Member For: 20y 7m 26d
Hi All,
Hoping you guys can shed some light on this.
I have a 2014 FPV F6, have had it from new, and its just kicked over 20,000Ks
Car is stock other than an XR8 Snorkel and lower airbox.
Went to a Dyno night on Friday, and got a real low reading, 201.9KW at the wheels.
That might be ok for a stock LS1, but think this is extremely low for the F6.
Car still feels as quick as it did when I got it, still pulls like a freight train.
Besides going to get a tune etc, what does everyone think is wrong here?
post-4081-0-46856500-1439199362_thumb.jp
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 6m 28d
Hey mate don't get to caught up in paper numbers but this might shed some weird light on your situation
First thing, there a harsh reading dyno
Second, it was run in third, should of been 4th but third will actually read higher so don't get to hurt there lol
Third, no one knows the correction factor that "had" been added could of been a -40rwkw factor hahaha
Some of the obvious things like a boost leak not letting the engine see full boost is possible with array of many things
You have a piece of laper telling u how the car was running at the time ( assuming the opperator was doing the correct things ) typically a FGF6 should be close to 240-250rwkw stock
Maybe have a look at the easy things like boost levels and go from there ;)
  • Like 3
  • 1 year later...
  • Member For: 14y 4m 8d
Most FG F6's usually run around 270 rwkw stock, also the NM was up in the 700's which is way more than standard, I would suggest the dyno wasn't set up correctly.
I'm dyslexic and cannot turn off simple functions in tapatalk
