rollex Member 683 Member For: 11y 23d Gender: Male Location: Australia Posted 06/08/15 04:47 AM Share Posted 06/08/15 04:47 AM (edited) So I'm looking at buying HP tuners VCM suite however the AUD sucks balls at the moment making it almost $900 for the software and cable from the US.Anyone know any way to buy it cheaper? I'm not looking at doing full tuning just tweaking existing tune so the $900 feels almost not worth it by the time I purchase a wideband set up as well.Is there any reason to buy the pro MVI interface that accepts the wide band input, eg can I do map tracing and show registered AFR for each cell if I buy this?If not am I better off buying the standard interface and simply logging via the SCT XCAL which I already have? Map tracing that can play history showing me exactly which cell and AFR at the time would be great if possible but not really sure how the software works until I buy it.Anyone here bought and used these products before? Edited 06/08/15 04:52 AM by rollex Link to comment https://www.fordxr6turbo.com/forum/topic/90954-buying-hptuners-vcm-suite/ Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 9m 8d Gender: Male Location: Perth Posted 06/08/15 06:02 AM Share Posted 06/08/15 06:02 AM Map tracing,no. Histograms showing 3 set of values - Yes. Ie rpm vs boost with lambda in each cell. You need the Pro for a wideband input otherwise you'd only be able to log commanded Lambda not actual. You can also log in table form,gauge form,scope form.I've had my MVPI Pro for 5yrs. $900 is a steal was over $1500 when I bought mine Link to comment https://www.fordxr6turbo.com/forum/topic/90954-buying-hptuners-vcm-suite/#findComment-1556764 Share on other sites More sharing options...
rollex Member 683 Member For: 11y 23d Gender: Male Location: Australia Posted 06/08/15 07:42 AM Author Share Posted 06/08/15 07:42 AM Ok if I can't map trace then am I better off simply datalogging with the XCAL and buying the standard MVPI ? Link to comment https://www.fordxr6turbo.com/forum/topic/90954-buying-hptuners-vcm-suite/#findComment-1556782 Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 11m 11d Posted 06/08/15 12:04 PM Share Posted 06/08/15 12:04 PM Have you downloaded the trial versions and had a look at them? Are you sure your tune is unlocked and you can tweak it?Hp tuning forum has a bunch of great info and basically everyone on that forum is on this forum anyway. Link to comment https://www.fordxr6turbo.com/forum/topic/90954-buying-hptuners-vcm-suite/#findComment-1556831 Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 22y 3m 1d Gender: Male Posted 06/08/15 01:16 PM Share Posted 06/08/15 01:16 PM Get the Pro mate, you will wish you had the wide band input once you start nutting it all out. You think you won't tune now but then you start playing building up your knowledge and before you know it you start thinking this sh*t aint that hard. Link to comment https://www.fordxr6turbo.com/forum/topic/90954-buying-hptuners-vcm-suite/#findComment-1556845 Share on other sites More sharing options...
rollex Member 683 Member For: 11y 23d Gender: Male Location: Australia Posted 07/08/15 12:12 AM Author Share Posted 07/08/15 12:12 AM (edited) OK I'll get the pro then.Have you downloaded the trial versions and had a look at them?Are you sure your tune is unlocked and you can tweak it?Hp tuning forum has a bunch of great info and basically everyone on that forum is on this forum anyway.I've downloaded the trial and had a brief look, planning on having a proper look this weekend.The tune was done by an XCAL, how do I know if it is locked? Edited 07/08/15 12:12 AM by rollex Link to comment https://www.fordxr6turbo.com/forum/topic/90954-buying-hptuners-vcm-suite/#findComment-1556870 Share on other sites More sharing options...
Skids4kids in the mid....not the bum like some Member 609 Member For: 12y 2m 8d Gender: Male Posted 07/08/15 01:13 AM Share Posted 07/08/15 01:13 AM So you plan on sucking the tuners work out and then changing it slightly? Link to comment https://www.fordxr6turbo.com/forum/topic/90954-buying-hptuners-vcm-suite/#findComment-1556875 Share on other sites More sharing options...
rollex Member 683 Member For: 11y 23d Gender: Male Location: Australia Posted 07/08/15 02:41 AM Author Share Posted 07/08/15 02:41 AM So you plan on sucking the tuners work out and then changing it slightly?That was the plan yes. I want to tweak the cold start and play with some of the cruise stuff to perfect it, the last 10% that takes 90% of the time if you will. Link to comment https://www.fordxr6turbo.com/forum/topic/90954-buying-hptuners-vcm-suite/#findComment-1556898 Share on other sites More sharing options...
rollex Member 683 Member For: 11y 23d Gender: Male Location: Australia Posted 07/08/15 02:56 AM Author Share Posted 07/08/15 02:56 AM So yeah if the tune was done in XCAL can it actually be locked? I've been told HPTuners can easily suck out the existing tune and simply tweak that.Yes/no/issues ? Link to comment https://www.fordxr6turbo.com/forum/topic/90954-buying-hptuners-vcm-suite/#findComment-1556902 Share on other sites More sharing options...
rollex Member 683 Member For: 11y 23d Gender: Male Location: Australia Posted 07/08/15 03:01 AM Author Share Posted 07/08/15 03:01 AM Can I get some recommendations on wideband sensor as well? Preference is something with narrowband simulation I can install permanently in the dump pipe. Link to comment https://www.fordxr6turbo.com/forum/topic/90954-buying-hptuners-vcm-suite/#findComment-1556904 Share on other sites More sharing options...
