Cmhendo New Member 6 Member For: 10y 1m 5d Posted 29/07/15 07:48 AM Share Posted 29/07/15 07:48 AM Have a pretty stock BA xr6t, has xr8 pod style filter, hi flow cat and 2 1/2 inch exhaust.I bought a flash tuner with a 11 psi tune on it.Is this too much boost for stock internals?If so could I just regulate the boost down to say 8-9psi with a boost controller?If not what PSI should I ask for in a custom tune?Thanks for the help!Chris H. Link to comment Share on other sites More sharing options...
rokkie Member 87 Member For: 12y 5m 15d Gender: Male Location: Adelaide, SA Posted 29/07/15 08:28 AM Share Posted 29/07/15 08:28 AM 14psi and valve springs here with stock internals. 300rwkw Link to comment Share on other sites More sharing options...
Cmhendo New Member 6 Member For: 10y 1m 5d Posted 29/07/15 08:34 AM Author Share Posted 29/07/15 08:34 AM Thanks! but what about with stock valve springs?Havent fitted the hi flow cat and exhaust but will before retuning it Link to comment Share on other sites More sharing options...
rokkie Member 87 Member For: 12y 5m 15d Gender: Male Location: Adelaide, SA Posted 30/07/15 09:53 AM Share Posted 30/07/15 09:53 AM Stock springs were struggling with factory boost. Not sure otherwise Link to comment Share on other sites More sharing options...
_Velocity_ Bronze Donating Members 2,768 Member For: 13y 10m 9d Gender: Male Location: Victoria Posted 31/07/15 01:07 AM Share Posted 31/07/15 01:07 AM (edited) FWIW you're best to get a custom tune for your car. Where's the 11 psi tune from that came with your flash tuner? Edited 31/07/15 01:17 AM by _Velocity_ 1 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,289 Member For: 16y 10m 24d Gender: Male Location: Melbourne Posted 01/08/15 04:15 PM Share Posted 01/08/15 04:15 PM With him ^^Flash the factory tune back in if running a generic tune and take your box to a tuner and get a custom dyno tune. The tuner will take your goals and platform into account and give the car a healthy amount of boost for the amount of power the platform can cope with safely in the current configuration. Link to comment Share on other sites More sharing options...
Cmhendo New Member 6 Member For: 10y 1m 5d Posted 13/08/15 11:36 PM Author Share Posted 13/08/15 11:36 PM Thanks for the advice Link to comment Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 13y 3m 4d Gender: Male Location: WA, Perth Posted 14/08/15 05:52 AM Share Posted 14/08/15 05:52 AM sounds like we may have another runner....As mentioned in the two posts before, please don't use email tunes. Instead of costing you 2k for a custom tune, it is gonna cost you a whole new motor.Each car is different when it comes to valve springs. It could be that your car won't need them replaced to get to 300kw(example), where as another car would need it.I was lucky enough that I didn't need springs, but I plan on getting them done next for peace of mind.If you going to fit a high flow cat, then you need a custom tune.Fingers crossed all goes well for you. Link to comment Share on other sites More sharing options...
Cmhendo New Member 6 Member For: 10y 1m 5d Posted 17/08/15 12:33 PM Author Share Posted 17/08/15 12:33 PM The 11 psi tune was put on there by bpr racing. I think now a custom tune would b best. Is there any point putting a bigger intercooler on before getting a custom tune or is it just a waste of money? Link to comment Share on other sites More sharing options...
ms700 Moderating Team 10,170 Member For: 22y 1m 3d Gender: Male Location: Sydney Posted 17/08/15 11:20 PM Share Posted 17/08/15 11:20 PM hi flow cat and 2 1/2 inch exhaust.If that is 100% true, id be getting that fixed first.2.5in is way to small for a turbo fed 4 litre engine. Link to comment Share on other sites More sharing options...
